3.0D XF S Portfolio - Alternator spec
Old Jan 23, 2019 | 09:06 AM
strongy's Avatar
Default 3.0D XF S Portfolio - Alternator spec
Hi
Would anyone be able to help with alternator spec please? Specifically what output should it be for this model to keep everything running?
Am I correct in thinking it is 150V?
Thanks in advance
Old Jan 23, 2019 | 10:56 AM
clubairth1's Avatar
Community Influencer
No Not 150V. Or do you mean 15.0V?
You should measure the battery voltage with the car off after sitting all night.
Then start the car and immediately measure the voltage again. Then after 15-20 minutes of running measure the voltage again.
Report back with all 3 readings.
A secondary question is how old is your battery and did you replace the alternator with a Jaguar one or get your original unit rebuilt?
Lots of problems if you used an aftermarket alternator and now I favor getting your original rebuilt if possible.
Old Jan 23, 2019 | 11:55 AM
strongy's Avatar
Sorry, I should have typed 150amps not volts
Old Jan 23, 2019 | 04:54 PM
JagV8's Avatar
It's probably the special type of alternator which the PCM can switch between voltages - don't fit the wrong kind!
Old Jan 24, 2019 | 02:08 AM
strongy's Avatar
I'm only getting 13.6v and red light on dashboard. New alternator & battery recently fitted.
Think I might have open circuit default on BMS??
Old Jan 24, 2019 | 12:37 PM
clubairth1's Avatar
You need to answer the questions above?
Is the replacement alternator a Jaguar alternator?
What are the other voltages I asked you to measure?
Leave the BMS stuff alone unless you have a code. Right now you know where your problem is. It's in the new alternator.
Now this is a guess and that's why I asked where the alternator came from.
Please let us know?
Jesse James
Feb 21, 2019 04:45 PM
JimC64
Jun 25, 2018 09:30 AM
JimC64
Nov 4, 2012 01:40 AM
JimC64
Apr 22, 2012 06:31 AM
CarBizIndio
Aug 9, 2011 08:38 PM
