65000 mile XFR any big bills coming up?
Old Sep 4, 2012 | 02:10 PM
Daveky's Avatar
Default 65000 mile XFR any big bills coming up?
Hello everybody,
Looking at three year old XFK with 65000 miles and wonder what big bills are likely in the next 10000 miles or so and if there's anything I need to look for as being done? Thanks
Old Sep 4, 2012 | 02:12 PM
Daveky's Avatar
Sorry should read XFR.
Old Sep 4, 2012 | 02:42 PM
VapourTrail's Avatar
There should have been a major service performed around 60,000 miles. Check to make sure that was done. If not, I would walk away from the car as the previous owner, in all likelihood, did not follow a proper maintenance schedule. That said, you can call a local service center or independent and find out what they charge for that particular service. Otherwise, it's pure speculation what could fail within the next 10,000 miles or even 35,000 miles.
Check the dash facia to see if it is delaminating. Replacement will cost you about $1800 if you simply can't live with a ripple or two. The Voice Activation will most certainly not be working. Jaguar had a number of "complaints" from customers on the early XF's about the system and thus "deactivated" it. They are supposed to be working on a fix, but I think the solution is a phantom one that they hope will fade away as the early cars drop out of warranty.
They used cheap fasteners under the hood for the fuse box, engine cover and cowl. If they are missing then it will cost you a few quid to replace them. The overhead reading lights have a tendency to come on and off for no reason. Usually a faulty or dirty switch and the mic(s) associated with the Bluetooth/Voice Activation tend to fail as well. Mine was fixed under warranty, so I can't give you a quote (Voice Activation might not work, but you should still be able to talk hands free via Bluetooth).
There have been some reports of the gear selector giving problems and maybe a few trim pieces on the early versions, but I haven't really run into anything like that on my XF Supercharged, only the damn felt thingy under the dash keeps falling down onto my feet. I still have to investigate that one.
It's an expensive car with a lot of gizmos. Things are bound to fail and Jag service, just like BMW or Mercedes service is not cheap. I would recommend the CPO warranty if it is available.
Good luck.
Old Sep 20, 2012 | 09:18 PM
Nemrosim's Avatar
Damn 65k mile car, any history on it, it could probably have led a rough life, i dunno, seems like too much mileage for too lil time.
Old Sep 21, 2012 | 10:16 AM
BigCat09's Avatar
I would look deeper into this car as the others said. I only have 26K miles on my XFR and I always visit the dealer to make sure all is taken care of. These cars are meant to perform and they should be taken care of with much needed care.
fast40driver
Apr 19, 2024 07:24 AM
1100me
Aug 27, 2020 11:37 PM
Fraser Mitchell
Oct 1, 2015 04:06 AM
XFR_Gold
UK & Eire
Sep 2, 2015 06:30 AM
dpappyp
Aug 27, 2015 06:31 AM
