aftermarket paddles?
Old Jan 8, 2015 | 07:05 AM
Blackcoog's Avatar
The paddle upgrade that Jag sells includes more than just the aluminum paddles. It's an entire assembly that includes the hinge and circuit board. It must be easier to swap by supplying the entire assembly.
Old Feb 22, 2015 | 04:27 PM
jahummer's Avatar
What do you think of these I did for my XKR?
https://www.jaguarforums.com/forum/x...-111963/page7/
Old Feb 23, 2015 | 08:38 PM
Gpalace's Avatar
They Look Awesome !! Nice work..I take it they will fit the XF?
Old Feb 23, 2015 | 08:53 PM
jahummer's Avatar
Thank you very much. They will indeed fit. If you would like a set, let me know.
Old Feb 23, 2015 | 09:55 PM
Redjaguar100's Avatar
They are awesome.. I guess that's something else that I must added to the list. Outstanding job jahummer.. This is why I love this forum..
Old Feb 23, 2015 | 10:27 PM
chuckh007's Avatar
Do they light up at night like the originals ?
Old Feb 24, 2015 | 09:29 AM
Gpalace's Avatar
Thanks How is the install? Easy to just replace with the existing paddles?
Old Feb 24, 2015 | 11:06 AM
  #28
Blackcoog's Avatar
They might be molded over the originals. Getting the stock paddles separated from the circuit board/switch didn't look easy. I'm not sure it can be done without cutting/breaking the plastic casing holding them in. Here are close up pictures of the stock ones removed. This site sells a carbon set for the XF.
Old Feb 24, 2015 | 11:52 AM
Gpalace's Avatar
If I read the posts correctly...he is creating with new OEM paddles and you will remove your old...and hold onto them...so you may be right ..he is going over new paddles supplied by dealer...hense 400$ for new device.
The other CF ones from the site look fatter not as long...and looks like the simply go over your existing for half the price?
Old Feb 24, 2015 | 12:24 PM
  #30
jahummer's Avatar
They do not.
Old Feb 24, 2015 | 12:25 PM
  #31
jahummer's Avatar
Very easy. Remove the screw that holds in yours and replace with the new ones. They are complete with new OE Jaguar electrics.
Old Feb 24, 2015 | 12:30 PM
  #32
jahummer's Avatar
The first set I made was indeed over the originals but it was a bit messy and a lot of hassle though the end result was perfectly fine. Now I am replacing the paddle by taking them apart with the right tools and know how, no cutting at all. The link you referred to is for stick on paddles and you can still see the originals looking at the wheel from the driver's position.
Old Feb 24, 2015 | 12:34 PM
  #33
jahummer's Avatar
That is correct and for what you get with the others, I think the price is a little high. Someone also found some aluminum ones for under $100 in China, but they are also stick on and look a bit cheap.
Old Feb 24, 2015 | 01:42 PM
  #34
Blackcoog's Avatar
Here are those Chinese designed paddles they do leave a bit to be desired but it's mostly the design not that fact that they are stick on. I'm sure they still function as intended.
Old Feb 24, 2015 | 02:36 PM
  #35
OzXFR's Avatar
I bought a set of those Chinese ones a few days ago, they should roll up any day now.
But in the meantime I am upgrading to an XFR, which I won't pick up for a week or so yet.
When I get both the car and the paddle extensions I'll fit them and see how they look, feel and work. I intend not to use the grub screws they come with, as that surely will put holes or dents in the edges of the original paddles, instead I plan to stick the extensions on with thin double sided tape.
Old Feb 25, 2015 | 10:51 AM
  #36
jahummer's Avatar
Ok, all new paddles are spoken for in the first batch, unless you want to send me your paddles and still get in this group. Let me know. I wiped out everything Jaguar USA & UK had in stock and waiting on confirmation when they will have more so I can start planning the next run.
Old Mar 2, 2015 | 10:03 AM
  #37
jahummer's Avatar
Good News for someone! I received the balance of my order from Jaguar this morning and there was one extra pair of stock paddles. Anyone who wants in, let me know.
Old Mar 3, 2015 | 07:47 AM
  #38
Big Dipstick's Avatar
You could try these paddles, although there may well be clearance issues!
Old Apr 1, 2015 | 11:12 AM
  #39
Alucardhell666's Avatar
How did the install go? Any pictures?
Old Apr 1, 2015 | 05:06 PM
  #40
OzXFR's Avatar
I fitted them a couple of days ago, sorry, no pics.
I was wary of the grub screws used to hold them in place, guessing that they would mark the existing paddles a fair bit, so I decided to stick the extensions on with double sided tape instead of using the grub screws. First time this didn't work all that well, the paddles came loose fairly easily. Second time I used thicker tape (first time was very thin tape), and now they stick well.
I haven't noticed any real improvement in feel or action.
BUT, I will be removing them in a short while.
Why? Because the right "+" paddle extension interferes with the "pull the stalk in" one touch windscreen wipe, which I attempted to use for the first time in a long time last night. It completely blocks the operation of this very handy feature.
So the extensions have to go.
