Ahhh! Rear Differential problem H.e.l.p!!
Old Apr 1, 2014 | 10:56 AM
gforce's Avatar
Originally Posted by Cambo351
Just be careful about which diff you get if secondhand, the XF had the e-diff which is not the same as the S-Type, X350 or the early X150 XK, I believe it's the same as the later X150 and the X351, but I need to check the parts catalog to be sure.
Can you check the catalog it help me alot please
Old Apr 1, 2014 | 04:06 PM
Cambo's Avatar
OK but I need to know the last six digits of your VIN.
Old Apr 2, 2014 | 07:45 AM
Blackcoog's Avatar
What type of fluid is recommended for the diffs? I'll pick some up and make sure it's still full.
Old Apr 2, 2014 | 10:10 AM
gforce's Avatar
The last six Vin# R14494 Thank you very much
Old May 9, 2014 | 09:23 PM
Jimi's Avatar
I'm feeling the rumbling described in this chain. Does anyone know if there's a spec fluid for the 09 SC diff? Also, how do I get to the plug, or do I (never been a mechanic) need a shop to do it?
Old May 10, 2014 | 04:56 AM
gforce's Avatar
Sorry to say if you feel the rumbling or hear the whine the diff is bad and needs to be replace cost is around $9500.00 just for the parts I just had mine replace to the new upgrade I might have 100 miles on it now still breaking it in.good luck
Old May 10, 2014 | 06:48 AM
jaguny's Avatar
Is the '09 the last year for this problem?
Old May 10, 2014 | 03:27 PM
  #28
2010 Kyanite XFR's Avatar
Don't think so. There have been a number of 2010's that have needed it as well.
Old May 10, 2014 | 04:00 PM
*Phoenix*'s Avatar
So can I assume that 2011+ are all good?
Old Apr 16, 2015 | 11:36 AM
  #30
aaronharstine's Avatar
This seems entirely focused around the XF Supercharged models. I'm about to purchase an '09 XF with 55K mi, is this something to look for in that car to? would a replaced diff under warranty show up on carfax?
Old Apr 16, 2015 | 12:53 PM
  #31
Blackcoog's Avatar
I think it was all of the 09s. I'd check the axles for leaks near the diff and listen for any noises. Even if it seems fine spend $50 swaping out the fluid. It takes about 15 minutes with a bottle of fluid and a pump. There might be an external marking you can check on to see if it was upgraded. I'd say chances are the vast majority weren't upgraded.
Old Apr 16, 2015 | 09:12 PM
  #32
Thanks, I went ahead and had the dealer I'm buying it from swap the fluid. I think I'm going to plasti-dip it in XFR blue and swap out the base model speakers to something that sounds less muddy. But so far i am very happy with the car!
Old May 9, 2015 | 06:04 PM
  #33
jagular's Avatar
Default This thread is related to another diff thread here
https://www.jaguarforums.com/forum/x...e-help-142146/
Old May 10, 2015 | 02:18 PM
  #34
clubairth1's Avatar
Community Influencer
You won't mistake the E-Dif. It's got the big electric solenoid hanging off of it.
Old May 11, 2015 | 07:10 AM
  #35
larryorgnist82's Avatar
Is that the original diff or the replacement? Mine does not look anything like that one. Now I am really confused.
Old May 11, 2015 | 08:09 AM
  #36
Blackcoog's Avatar
He said it's the E-diff which is the diff in the 5L Supercharged and XFR models.
Old May 13, 2015 | 02:05 PM
  #37
Bigg Will's Avatar
Well if mine goes once the warr. is done, I'm looking into something like this. From what I've seen the XF's diff is real close to the Jag S-type/ Lincoln LS's as far as parts utilization?
Jaguar Quaife Differential Install ? Jacks Transmissions
Old May 13, 2015 | 02:17 PM
  #38
jagular's Avatar
XF is an S Type with a different bodyshell. However, a number of mechanical parts were updated so it would be worth checking MY and VIN with any supplier.
A Quaife Torsen diff would be a big upgrade for the XF without the ELD.
Old May 13, 2015 | 02:18 PM
  #39
jagular's Avatar
2009 SC had the standard open diff. The ELD was introduced on the R model and only came on cars fitted with the 5.0 supercharged V 8
Old Feb 25, 2016 | 08:14 PM
  #40
Fernando1's Avatar
Does a 2010 differential work of u change the axles or no
