am new and need help 🥲
Old Jul 30, 2024 | 04:13 AM
PummeN's Avatar
Default am new and need help 🥲
hello i bought my first jaguar xd 2011 5.0 n/a
yesterday my car showed coolant level low till i got home it showed engine overheating off course i stopped waited for a bit and then slowly got home it wasn’t far away but before i got home till 1.8 2k rmps you could hear slight rattling so is because the coolant level are very low all most emty or its more damage than just coolant leak
i forgot to mention that at some point my power steering disappeared and then it started working again
Old Jul 31, 2024 | 07:00 AM
aliuser's Avatar
Check the coolant storage box for any small leaks and hose piples or replace it also check the water pump if its running properly.
Old Aug 7, 2024 | 12:25 AM
2010XFPushBrakeHarderToStart's Avatar
Fill the coolant and go around the block, see how it sounds. Stop with engine running and have a look under the hood for leaks.
Old Aug 7, 2024 | 06:01 AM
PummeN's Avatar
so it’s leaking somewhere behind the engine on the driver’s side the leak only leaks when you release the gas pedal but like when you press the gas it doesn’t leak and its like a big leak
Old Aug 7, 2024 | 08:48 AM
clubairth1's Avatar
Community Influencer
Keep reading your 5.0 engine has an entire list of failure prone plastic cooling parts and I would plan on replacing all of it at one time. Otherwise you will be redoing the repair as the parts fail one by one.
DO NOT ignore this as the number one reason to destroy your engine is something breaking and then over heating the engine. Again and again DO NOT drive the car any further if it's leaking coolant or running hot.
Can you DIY the repairs? Otherwise plan on an expensive trip to the shop. Don't forget to include the water pump too as I am surprised that has not be replaced already?
tampamark
Sep 7, 2025 07:54 AM
Aix
Aug 31, 2023 08:38 AM
thatjagtho
XE ( X760 )
Jul 11, 2023 11:09 AM
CJSJAG
May 15, 2023 04:28 PM
Diamondrmp
52
Dec 19, 2012 02:52 PM
