Auxillary Junction Box (body Control Module B) Error code 901
Old May 14, 2018 | 02:14 PM
harryf's Avatar
Default Auxillary Junction Box (body Control Module B) Error code 901
Has anyone gotten this code? I can't seem too do any CCF Editing the front modules for the door and I am also getting a central junction non communications error on SDD.
SDD is using the PCM as the main CCF. Does anyone know how I can reset this?
I'm not sure if this came about when I had hooked up my charger to the battery when using SDD.
Really weird.
Old May 14, 2018 | 02:36 PM
elviukai's Avatar
I see audio upgrade progress is on its way
Old May 14, 2018 | 02:48 PM
harryf's Avatar
Unhappy
It's been going on for several months, just put in the surround sound speaker in the center and had the rear deck with surround sound put in.
However my reprogramming on the amps are going nowhere. And that is why I've been asking for help on the reprogramming of the amps as well as what needs to be changed in the CFF for the amps.
Something went awry as the AMP does not produce sound anymore.
And of course the issue above is what I am facing today.
Old May 14, 2018 | 03:22 PM
harryf's Avatar
Unhappy
Duplicate post. please delete.
Old May 14, 2018 | 06:27 PM
harryf's Avatar
Well, for whatever reason the Auxiliary Junction Box is working again but the Central Junction Box is not. Any ideas?
Old May 15, 2018 | 01:42 AM
elviukai's Avatar
I do not want to frighten you, but seems some indy will need reprogram or order new 2 junction boxes.
from the begining it was clear that things will go wrong. it was just matter of time. before doing anything its best to know ourselves abilities which directly related to information we have. you just cant use amplifier if you see premium 16 stick.. and cant change CCF all the way you want. its not PSA cars, Jag computers/programing is very tricky. once i reprogrammed TPMS wroingly and car went to RPM rising infinitely nearly brickiing cold engine and later check engine was displayed. this is for programing tyre presure monitoring system. you can image what you do here. jsut dont brick your car completely.
Old May 17, 2018 | 02:54 PM
harryf's Avatar
Well, I wish that I had some guidance, I was using the guidance of Cambo's post however and everything seemed to go well till I tried to install the surround sound system and upgrade the amp. As I have had failures of a couple of amps already through programming, I am afraid to buy another one with the specific model number and have it fail. Of course the Central Junction Box is not working currently, and this will cause any CCF programing to fail. I didn't know how specific the part number had to be to make this work on my car. From Cambo's information I had thought that a bunch of amps would work, based from his other post on the XJ and F-Type forums. I got a good deal on the amps but they didn't work. Unfortunately there doesn't seem to be anyone in the Washington DC area who does these types of upgrades otherwise I would have gotten them to do it. I think my mechanic only does engine and body work and not electronics. Anyone know of a specialist in the DC area who does this type of work?
Lafe
Oct 11, 2017 03:09 PM
awegrzyn
Sep 23, 2016 02:59 PM
bradstuff
Sep 28, 2014 10:02 AM
Sumrfun
Aug 3, 2012 11:06 PM
dannygjatt
May 14, 2012 09:02 PM
