Battery died again -- any ideas?
Old Feb 8, 2015 | 01:25 AM
  #61
chuckh007's Avatar
With reserve capacity of at least 170, your problems (most that is) will be over. !!
Old Feb 8, 2015 | 02:59 PM
  #62
sparkenzap's Avatar
Mr. Bollocsk:
" The battery location is STUPID in the JAG"
You sir, are dead wrong. The battery location, for you, may be inconvenient, but there are several good reasons for the placement where it is.
1) Heat lessens battery life. Under hood is hot.
2) Weight balance is good. Most cars are front heavy and moving it rearward helps balance.
3) At least in my XFR, there is too much engine in the engine bay for a big battery to fit.
There are a number of inconveniences associated with a real high performance car. That is why so many pseudo sports cars are sold.
Old Feb 9, 2015 | 10:19 PM
  #63
bollocsk187's Avatar
Originally Posted by sparkenzap
Mr. Bollocsk:
Yes you are correct. I fully retract my stupid comment. Once I pulled the battery out I realized what a friggen monster in weight and size. I think i got a hernia. Bought a $200 Autozone H8 AGM platinum battery, replaced it. Then I noticed the original battery was less than 6 months old I nticed that the fluid level was low . I took it to the dealer got a new one for free ! ROFL
I also like being called "Mr" and "sir" it is a British thing
Old Feb 9, 2015 | 11:57 PM
  #64
sparkenzap's Avatar
Just living the Jag-u-wah life, mate!
Glad you got it fixed!
Old Oct 8, 2019 | 01:18 PM
  #65
Jbdynamite's Avatar
Default Battery drain
[QiUOTE=Long Islander;619411]After sitting idle for two days, my car had to be jump started today. Ten days ago, it sat idle for three days and had to be jump started.
Back in August, same thing after sitting for 2 days. Right after that, I took it to the dealer and they said the battery and electrical system both tested fine.
Today, I took it to the dealer again and they said everything was fine, but they'd keep it overnight to check it again tomorrow.
Just over a year ago, after another couple of dead battery incidents, I took it in and they did the software update to make sure the infotainment system was turning off when the car was turned off, so that's no longer the problem.
Any ideas? This is a bit of a bother.
2010 XF Premium (5.0)[/QUOTE]
I had the same problem recently. I noticed the light in the push button panel stayed in where you see the navigation, etc. Make sure the light is off when parked. It solved my problem.
Old Oct 9, 2019 | 02:20 PM
  #66
clubairth1's Avatar
Community Influencer
Please read this thread above your post. Did you see where your car needs an update since your center screen is not shutting off?
He even posted the TSB. Please print it out and take it to the dealer when you go to get it fixed.
Old Oct 9, 2019 | 02:28 PM
  #67
Jbdynamite's Avatar
[QUOTE=clubairth1;2137259]Please read this thread above your post. Did you see where your car needs an update since your center screen is not shutting off?
.sorry i did not read the entire post. I was just glad to find a solution to my problem, and thought i would share is. Thank you.
.lQUOTE]
Forcedair1
Sep 8, 2025 01:57 PM
Dagny
Jun 11, 2024 01:06 PM
99xk8guy
May 28, 2024 09:36 PM
mbergen
Oct 23, 2019 10:26 PM
DEklof
Sep 8, 2015 05:28 PM
