Battery Drain
Old Jun 23, 2022 | 12:05 PM
EZED's Avatar
Default Battery Drain
My 2010 XFR has a big battery drain. I have no service engine lights and nothing on history report. When battery gets low my screen goes blank, A/C goes off and on etc. until car won’t start. Any input with like problems would be appreciated.
EEH
Old Jun 23, 2022 | 03:33 PM
User 42324's Avatar
Are you certain it's a drain ? Have you checked your battery ?
Old Jun 23, 2022 | 04:12 PM
EZED's Avatar
I have two new batteries keep one always at full charge to swap out. There is a rather big spark when I attach the positive line when changing out batteries. Yes I have replaced negative battery cable.
Thanks for the input,
EZED
Old Jun 23, 2022 | 05:08 PM
Oxidizer2k's Avatar
Do you keep anything plugged in the obd port? Like a Wi-Fi/Bluetooth obd device?
Old Jun 23, 2022 | 05:17 PM
EZED's Avatar
Nothing.
Thanks,
EZED
Old Jun 23, 2022 | 05:28 PM
Oxidizer2k's Avatar
Have you been able to check your voltage being produced by the alternator as well as have the batteries load tested?
Old Jun 23, 2022 | 05:49 PM
NBCat's Avatar
@EZED, what is the battery voltage across the terminals with the ignition in the OFF position when checked with a voltmeter?
Old Jun 23, 2022 | 05:55 PM
EZED's Avatar
EZED
Old Jun 23, 2022 | 06:00 PM
EZED's Avatar
Alternator putting out 15 plus volts. 2 new batteries same result on both.
Thanks,
EZED
Old Jun 23, 2022 | 07:23 PM
NBCat's Avatar
For the CAN and modules to correctly function, there should be a minimum of 12.6 volts present with the ignition off.
If you charge the battery currently in the vehicle for five hours at 2 to 5 amps and retest it again, there should be at least 12.6 volts available. If not, the battery is suspect and should be replaced.
Did you previously check the vehicle for a parasitic draw?
eeeeek
Nov 27, 2023 12:08 PM
cdma
Nov 21, 2021 07:34 AM
Peter 2700
17
Nov 25, 2020 10:13 AM
Craighead
Mar 8, 2015 09:31 PM
