Battery not charging and unidentified cable.
Old Apr 15, 2025 | 09:40 AM
clubairth1's Avatar
Community Influencer
The BMS will self calibrate and I have never used SDD to reset it and have never had any problems doling it this way.
Old Apr 16, 2025 | 01:10 PM
X2002's Avatar
Update: My local independent mechanic found that oil that had been leaking from the valve covers got in to the alternator, causing the intermittent fault. Next step is going to cost $1,200 to replace the alternator. The worst part of this story is that I finally tired of wiping oil off my garage floor and had the valve cover gaskets replaced just last week for $2,000. If I had asked the mechanic to check the "battery not charging" warning before replacing the gaskets I could have saved quite a few hours of labor. My bad for ignoring the warning light for too long.
Old Apr 17, 2025 | 09:27 AM
clubairth1's Avatar
Hey don't feel bad you can only fix what you know about. The alternator failure was bad luck for sure.
Hopefully your experience will help others with similar problems.
Fix the cam cover oil leaks or else risk an additional alternator replacement.
Forcedair1
Sep 8, 2025 01:57 PM
Rivguy
Nov 13, 2022 02:55 AM
gold59
US Lower Atlantic
Sep 16, 2015 06:27 AM
Charlene n John
Sep 14, 2015 10:08 AM
jaguarbill
Sep 5, 2015 11:43 AM
