battery on xf
Old Apr 22, 2018 | 02:18 AM
scotsgeeza's Avatar
Default battery on xf
hi all im getting intrmittent restricted performance and dcg not engaging do i need a start stop battery or normal
on 2008 2.7 xf luxury premium deisel or is it something else
many thanks
george
Old Apr 22, 2018 | 02:21 AM
scotsgeeza's Avatar
ps i also hear theres 2 batteries do i need to replace both
tia
g
Old Apr 22, 2018 | 02:56 AM
OzXFR's Avatar
No stop start and only a single battery on a 2008 XF.
And yes, a failing battery will cause your problems and if the battery in the car is the original it is well past due for replacement.
A normal flooded cell lead acid battery is OK (as long as it's at least 90 amp hours and 750 CCA) but a more modern AGM battery (commonly used in cars with a stop/start system but perfectly OK for those that don't) is better although more expensive.
Old Apr 22, 2018 | 03:13 AM
scotsgeeza's Avatar
hi mate thanks for reply i had a heavy duty battery put in my old s type bout 4 months ago would that be ok
regards
george
Old Apr 22, 2018 | 04:06 AM
OzXFR's Avatar
regards
george
Yep, it will probably be OK, just make sure it is sufficiently rated, the right size and shape to bolt straight in, and put it on a battery charger first to bring it right up to 100%.
Old Dec 22, 2020 | 07:12 AM
jwballes's Avatar
Thanks; i just intended to open a threat to ask if a AGM battery can be used in a 2011 model (3.0D) with a single battery
Now i know the answer
John Alles
cat_as_trophy
Nov 29, 2025 11:08 AM
snkpkp
Jan 14, 2021 09:52 AM
BigCat09
Dec 4, 2019 03:06 PM
Mark Scotton
24
Jan 23, 2013 09:27 PM
