Brake pad sensor bypass
Old Feb 22, 2026 | 01:29 PM
allterrain's Avatar
Default Brake pad sensor bypass
Hi all I'm new to site so hello to all
My question is for my xf 2015 2.2 diesel xfr which has low pads sensor light on now I've tried to join wires on NSFW and osr but the sensors are broke before the plug connector meaning I've joined them carside not wheel side so would it matter as that's why light is still on or doesn't it make a difference as if it does is there any other way of getting light off or bypassing as can't use new sensor now as it's broke before the connector sorry to sound stupid but I'm not sure it makes a difference if it's joined before or after sensor any help be great thank you all
Old Feb 23, 2026 | 06:09 AM
webb 72's Avatar
the only time the icon luminates on the dash is if the sensor piece that attaches to the brake disc has worn through which creates a ground
or could be the two broken wires and there making contact with each other
I wouldn' worry about trying to fix them their pretty cheap to replace, I get mine on Amazon
Can you see the raised bit on the small piece, if that's showing signs of metal then throw it away and get new ones.
beazley1
Jul 7, 2025 02:41 PM
Speedmaster
Jun 15, 2024 08:01 AM
Rondog
Apr 19, 2022 06:34 PM
Jaguar Dre
XJ40 ( XJ81 )
Jun 27, 2017 11:09 AM
Eratostenes
Mar 21, 2017 04:00 AM
