XJ ( X351 ) 2009 - 2019
brake service light still on
Old Jul 7, 2025 | 01:22 PM
beazley1's Avatar
Default brake service light still on
replaced front brakes and sensor.
brake service light does not go out.
used scanner to try to erase and disconnected negative battery terminal.
light is still on.
back brakes still about 40% so dont think the rear sensor is triggering this. front brake needed it and sensor was affected, so replaced front sensor.
anyone have any ideas how I can get the light to turn off.
2018 XJ R Sport model.
Old Jul 7, 2025 | 01:32 PM
Vasara's Avatar
The pad sensor circuit work so that if the loop is broken, the light will lit. So check the sensor wires and connectors. You can try to "jump" the loop on sensor connector to check if you have faulty sensor or just use multimeter to measure the sensor itself from connector (on Ohm setting)
Old Jul 7, 2025 | 02:41 PM
JoshMcMadMac's Avatar
The sensors can be sensitive and easily broken, even when new. If you still have the old sensor, you can cut the sensor end off and twist the wires together to make a jumper. Plug that in instead of the new sensor, that will rule out the sensor as your issue.
Rondog
Apr 19, 2022 06:34 PM
jagnew
May 12, 2021 01:36 PM
Ken Scott
Sep 15, 2017 02:30 AM
platinummaker
Jan 20, 2014 08:14 PM
