Brake pads low message
Old Nov 15, 2022 | 03:55 AM
Robu's Avatar
Default Brake pads low message
Hi guys have replaced both sensors rear pads and calibrated the hand brake. Front pads were not half worn. Can not reset the message have tried a reset sequence from utube and disconnected the battery.
Message still displaying any suggestions?
Old Nov 15, 2022 | 07:06 AM
POD XF's Avatar
Something that might be worth trying; disconnect the battery cables and then touch the negative and positive terminals together (the wires, not the battery terminals!). This is a bit of a shortcut way to clear fault codes, I have used it on my 2008 XF with success but not specifically for a brake pad message.
Old Nov 15, 2022 | 08:22 AM
clubairth1's Avatar
Community Influencer
They are easy to bypass so I would go to each sensor and short the two leads together temporarily. Do this one sensor at a time. The message should go out when you find the right circuit causing the problem. Somewhere the system is seeing ground which turns on that message.
Was the message on before you worked on the brakes? If so the sensor is ruined and must be replaced. It was not clear when you said you replaced the sensors so maybe they are all new?
Old Nov 16, 2022 | 01:04 PM
Robu's Avatar
thanks for the replies it was one of the new mintex sensors that was faulty can't trust any thing!! Cheers guys
Old Nov 17, 2022 | 08:21 AM
clubairth1's Avatar
Glad you found it!
Are you bypassing the sensor or replacing it?
yidal8
Sep 19, 2022 03:28 AM
derrickonline
Jun 5, 2020 08:48 PM
NightHawk
Aug 9, 2018 11:57 PM
skullbiker
Jan 31, 2016 02:54 PM
