Cambelt Replacement Advice
Old Jun 14, 2021 | 05:15 AM
Raheny's Avatar
Default Cambelt Replacement Advice
Hi All
First post in a long while - great to see the Forum continue to be such a wonderful resource.
I'm confused about the cambelt/ timing belt replacement interval, as there is conflicting advice about this, and the car's manual says, well, nothing about when this should be done, surprisingly. I was told by the garage where I bought the car that it should be done at 112,000 miles or 10 years, whichever is sooner. However, having Googled around, I see the cambelt replacement is sometimes recommended at 7 years, and sometimes the mileage allowance is higher. My 2013 XF now has 142,000km/ 89,000 miles and is due an annual service. There is no record of a cambelt replacement in the service history. So, 8 years' old and 89,000 miles. Any thoughts? Engine sounds and performs fine, but I know these things sometimes give no warning before failing.
Many thanks
Jonathan
Old Jun 15, 2021 | 07:00 AM
Raheny's Avatar
I should add it's a 2.2D (200PS) model.
Old Nov 9, 2021 | 08:40 AM
Chouan's Avatar
From: From Co.Durham, now an economic migrant in Cambs.
Pity that there's no reply, as i was about to ask a very similar question!
Old Nov 9, 2021 | 07:04 PM
BritCars's Avatar
What engine do you have?
Old Nov 10, 2021 | 03:24 AM
Chouan's Avatar
The car is a 2011 XF, with a 3.0 diesel engine.
A further point,does anyone have any idea of the cost?
Old Nov 10, 2021 | 08:55 AM
Fraser Mitchell's Avatar
At 8 years and 89k miles, I would say you are due a cambelt replacement, but unfortunately I don't know the exact interval between belt changes. What I can tell you is that as far as I know, there is also a belt at the back of the engine for the high-pressure fuel pump which is normally replaced at the same time as the main timing belt. So doing both belts is obviously more in labour. It is not a cheap job, but then, no job on a Jaguar ever is !
The internet seems settled on 7 years or 112k miles, so you're overdue.
Edit
Just found this, hope it helps: -
http://replace-timing-belt.com/how-t...-3-0d-v6-2010/
Old Nov 13, 2023 | 01:58 AM
Digritz's Avatar
Question 3.0v6 d Cambelt replacement - cost.
Hi all, thought I would post on this site... Im about to get the cambelt done on my xf 3.0v6 d, but I was watching a movie on the car on Youtube, from 2021, and the guys said it should be around £400-500... and a service £300-400. I've been quoted £850-£1000 for the belt change by a jag specialist in Taplow, near me, should I shop around ?!
Cheesman4780
UK & Eire
Feb 6, 2019 10:44 AM
Niekere Rikhotso
Nov 5, 2017 12:41 PM
Jaymo
Jan 27, 2017 09:17 PM
carealtor
Sep 20, 2015 03:56 PM
steelman3
Dec 5, 2013 05:17 PM
