Car alarm
Old Mar 2, 2018 | 05:32 PM
Dj5ivestar's Avatar
Default Car alarm
My alarm keeps randomly going off from time to time in the 09 Jaguar XF
Old Mar 2, 2018 | 10:04 PM
OzXFR's Avatar
The first culprit to check for is an old or failing battery, these cars are very sensitive to battery condition and do all sorts of weird and wonderful things when the battery is dodgy.
If you still have the original battery in an 09 then it's well overdue for replacement.
The second thing to check for is a stray critter crawling around inside, do you get big spiders in your neck of the woods?
Old Mar 3, 2018 | 12:22 AM
BritCars's Avatar
Can you pull the codes from the system? It will tell you the last (10?) triggers for the alarm. Typically your symptom is a failing sensor for one of the doors. The bonnet/hood is often the culprit. If you can work out which one it is, it's pretty cheap to replace
daves_ale
Dec 28, 2017 11:04 AM
Thunder Bay John
Mar 29, 2016 03:26 PM
Translator
Jun 29, 2011 10:20 AM
vahdam
Apr 23, 2010 11:07 AM
adam12hicks
Feb 12, 2009 11:39 AM
