Car died, needs new engine
Old Nov 20, 2019 | 08:19 PM
jgjc3's Avatar
Default Car died, needs new engine
I have a 2015 XF with 82,000 miles on it.While driving on the freeway it lost power. Repair shop tells me it needs a new engine. ($7,000 for one with 50,000 miles on it). Anyone else have this occur? Dealership claim to not know about other problems like this.
Old Nov 20, 2019 | 08:52 PM
BritCars's Avatar
Sorry to hear that. What happened? Did you lose coolant and overheat it? That can kill them
Or oil starvation?
Would need to know more to understand if it's a known issue.
Old Nov 20, 2019 | 11:57 PM
StuG's Avatar
Subscribed
Old Nov 21, 2019 | 03:40 AM
Fraser Mitchell's Avatar
Very unusual for an engine to totally fail at that sort of mileage. If you tell us more we might be able to help with sorting it out, like what engine ? Is the repair shop a Jaguar agent or specialist ?
Old Nov 21, 2019 | 05:11 AM
Supercharged81's Avatar
I would definitely want to know what caused the failure, overheating, blown head gasket etc. If the dealership is involved, I would also get a 2nd opinion on a repair of that scale.
Old Nov 21, 2019 | 07:14 AM
jgjc3's Avatar
Or oil starvation?
We haven't approved any repairs yet so we aren't sure of what caused it exactly. I think we may get a second opinion.
Old Nov 21, 2019 | 07:37 AM
lotusespritse's Avatar
Lost power like completely turned off, or more like limp home mode?
Old Nov 21, 2019 | 08:20 AM
pab's Avatar
pab
We need more details, codes, fluid leaks, does it crank/start, if so is it noisy?
Current Hers: '13 Lexus ES350
Current Mine: '15 XF (X250) Portfolio AWD
Jaguar - making mechanics out of customers since 1935
Old Nov 21, 2019 | 08:32 AM
Brutal's Avatar
We see it, usually associated with low coolant, kept driving because coolant temp didnt show overheat(doesnt show accurate temp when no liquid is ob the sensor) or didnt notice. Then the engine gets so how it melts the plasric fuel line that runs across the back of the engine. You really need more info on why they said needs engine. How did the determine? Low compression etc
Old Nov 21, 2019 | 09:36 AM
jgjc3's Avatar
Their notes say engine has low compression, camshafts are not spinning with crankshaft and they recommend replacing the engine.
Old Nov 21, 2019 | 10:12 AM
That is a wild diagnosis! That would mean something with the timing chains broke. Not something I have heard before. With rubber timing belts, yes, but not with chains.
If that's really the case, then you would have so much engine damage that you would be better off with an engine replacement.
What engine do you have? 3.0L Supercharged?
Old May 20, 2020 | 10:59 AM
melwax's Avatar
What ended up happening with your car? I just posted a similar experience with 2015 XF 3.0 AWD with 65,000. Being told there is no compression & engine needs to be replaced. warranty just expired in November.
Old May 24, 2020 | 08:06 AM
F1Virginia's Avatar
So sorry Melwax..
Perhaps jgjc3 sold their Jaguar to cut loss?
Shame about the newer aj126 3.0 V6 engines suffering catastrophic failures; just like it's big brother 5.0's have done on rare occasion.
From my forum and cars.€om listings research, the older n/a V8's from x350 seem to run beyond 230k but I simply don't see that reliability beyond 130k in x351/x250/x260.
After reviewing hundreds of NHTSA complaints of these 3 models it's obvious that Jag has 3 serious low.mile defects with their s/c engines.
7th Water Pump Revision.
Thermo Seam Failure
Coolant Pipe Failure
Whereas BMW I-6 engines suffer oil & coolant issues, their V8's are long known for valve guide failures and now hotV turbo failures. Maserati are now seeing engine failures after just 6 years service.
Makes me sad as I love and respect these brands since my teen years in the 80's the new forced induction engines clearly are under-engineered vs their oiling / cooling needs.
Nearly all Jaguar owners rightly & stoutly defend and seem to deeply love their cats.
Perhaps no other car company offers such Space, Grace & Pace under $200k.
Old May 29, 2020 | 11:15 AM
clubairth1's Avatar
Community Influencer
Without him reporting back we can only guess?
He should have listened to Brutal and got a more complete answer.
Maybe he did and just did not come back to let us know?
jdhaynes
Sep 12, 2018 10:48 PM
04xtype04
Jun 1, 2014 07:47 AM
alwr333
Jul 10, 2009 10:29 PM
Jul 16, 2007 01:49 PM
