car not starting after rear caliper replacement
Old Nov 11, 2023 | 06:05 PM
13XF's Avatar
Exclamation car not starting after rear caliper replacement
I am having a problem Starting My Car,
I just changed the rear pads and caliper on my 2013 XF V6 SC with 83,000 miles. I tried to start it after flushing the brake fluid, and the dash came on, but the engine didn't start. I get the “press the brake pedal while starting” message. I press it all the way to the floor, and it does nothing. The only thing I hear is two click sounds from the engine. I checked the battery, as suggested in other posts, and it is fully charged. I bleeded all the brakes. I used 2 person method. The only thing I can think of is that the starter has gone bad, but the car was working perfectly fine before. So I have no idea what could have gone wrong while replacing the rear calipers.
Any suggestions?
Thank you
Old Nov 14, 2023 | 03:09 AM
JagV8's Avatar
Battery too flat?
Old Nov 14, 2023 | 06:24 AM
f-driver's Avatar
Any suggestions?
Thank you
Maybe your brake pedal switch went bad during the 2 person bleeding process ...
Old Nov 14, 2023 | 10:52 PM
lotusespritse's Avatar
Similar discussion here:
https://www.jaguarforums.com/forum/x...brakes-216352/
dericjohns87
General Tech Help
May 21, 2022 07:57 AM
AdamStudna
May 10, 2021 08:42 PM
lolshto
Oct 18, 2020 02:57 PM
jomo
Sep 23, 2020 03:32 AM
Vegas_Jag
Oct 11, 2019 10:28 AM
