Car won't start after new EGR installation
Old Aug 27, 2024 | 01:57 PM
  #41
kult's Avatar
Ok, found it mate, will test tomorrow and let u know
https://www.jaguarownersclub.com/for...test-mode-etm/
Old Aug 27, 2024 | 02:15 PM
  #42
sportbrake_phil's Avatar
Originally Posted by kult
Hi Phil,
By internal cluster instrument you mean the clocks themselves or the cluster? I have updated the cluster with SDD to the newest version after the key / bcm problem.
I meant, some faulty electronics in the cluster unit ( not specifically the dials/motors, as they're both playing up it's more likely in the driver circuitry - something common between the two maybe a voltage regulator, or a dodgy data line on an internal parallel bus intermittently dropping one of the bits due to bad transistor/dry joint for that line )
Old Aug 27, 2024 | 02:22 PM
  #43
kult's Avatar
Understood, I will test engineering mode first, then I will see if there is anything in SDD to fix it with.
Thank you
Old Aug 28, 2024 | 05:51 AM
  #44
kult's Avatar
Hi Phil, I followed this:
  • Press and Hold the 'Trip' button on the light switch stalk
  • Press and hold the 'Start' button (foot OFF Brake) whilst still holding in Trip Button
  • Count 5 Seconds, release 'Trip' button whilst still holding start
  • Foot on Brake, Engine will start, cluster will display 'Engineering Test Mode'
  • Cycle through screens using the Trip button for Gauge tests, Battery, Fuel etc etc information
  • Stop engine to clear test mode.
Engineering mode works, however when I start the car, depress brake pedal, it disappears I tried few times. Is above procedure correct?
Old Aug 28, 2024 | 06:57 AM
  #45
I'm not sure, I'm sure I did it at one point, at a guess I'd say try "foot on brake" while still holding the trip button.
Old Aug 28, 2024 | 01:39 PM
  #46
kult's Avatar
I tried foot on the pedal and other combinations, nothing worked, as soon as engine starts, it exits the engineering mode. Have to do more research... Everything is difficult with jags.
njsherlock
XF (X260)
Apr 21, 2023 04:21 PM
MCW739
Dec 5, 2022 07:49 AM
harryxtype
Mar 3, 2018 12:56 PM
xtype62
May 31, 2016 06:30 AM
snoopsmydogg
Diesel variants - All models
41
Mar 1, 2016 06:49 AM
