Changed Out Spark Plugs on 70k Mile 09 XF SC
Old Jun 2, 2012 | 07:31 PM
09XFSuper's Avatar
Default Changed Out Spark Plugs on 70k Mile 09 XF SC
I pulled out the stock NGK Iridium plugs with 70,000 miles on them and installed new Bosch Iridium plugs. I unbolted and moved the coolant tank to gain better access on the drivers side, one side of it is held in place with a plastic bracket that I could not seem to maneuver the tank enough to free the bracket, ended up breaking the bracket. I drilled a hole in the remaining part of the bracket and zip tied it to the tank when reinstalling, there is still a nut on a stud and a bolt holding the tank in place, no big deal. A swivel is required to access the plugs, there is not much room on either side, the rear plugs are a PITA, the stock plugs were tight and difficult to remove but they came out.
Attached is a pic of the plugs I took out, there is a hard white substance built up on the electrode on most of them, they still worked fine but for the price of $31.84 shipped after rebate for the new plugs and about 3 hrs work start to finish it was worth it to me to change them out.
I used anti seize on the threads of the new plugs and they easily turned in by hand and then I snugged them up with the ratchet. I put a bit of di-electric grease into the plug boot with my little finger and spread it around, the plug boots slipped nicely on to the new plugs.
All in all not a terribly difficult job and the average do it yourselfer should be able to do it, I did curse and swear a bit, mostly while removing and re-installing the coolant tank!
Started it up and it ran perfect!
Attached Thumbnails Changed Out Spark Plugs on 70k Mile 09 XF SC-img-20120602-00497.jpg
Old Jun 3, 2012 | 01:04 AM
rasputin's Avatar
any reason why you went with the Bosch's over the NGK's?
Old Jun 3, 2012 | 01:09 AM
jagular's Avatar
Plugs look a tad lean. Unless the camera flash just makes them look white. Grey tan colour is more normal for other engines I've pulled plugs out of.
Old Jun 3, 2012 | 05:45 AM
09XFSuper's Avatar
Everywhere I checked the Bosch's were half the price of NGK's. Figured Bosch wouldn't be cheap quality, hopefully.
Old Jun 3, 2012 | 05:47 AM
09XFSuper's Avatar
The color is kind of greyish, I recently ran a couple bottles of fuel injector cleaner thru the car, don't know if that would make a difference. The engine and ecu are stock.
Old Jun 4, 2012 | 12:17 PM
NvmyJag's Avatar
I'm curious why you changed the plugs @ 70k. I was under the impression Jaguar changed them @100k on the 4.2’s .
The whole zip-tie thing has me shaking my head . If I was in the market for a car and saw a zip-tied fix it would make me question what else might be super glued/zip-tied/duct taped or rigged.
You are from NASCAR country; we are supposed to set the example !
Old Jun 4, 2012 | 02:15 PM
09XFSuper's Avatar
My personal feeling is that the car companies have stretched out their maintenance intervals as a means to sell more cars (look how little maintenance our cars require!). For my peace of mind I changed them out and it may all by in my head but man it sure feels like it runs better and that is good enough for me. I also changed out every drop of fluid in the car, makes me feel better and that is the most important, it doesn't cost much financially either.
I had to zip tie it in place until I can buy a new plastic bracket, even so putting that new bracket on is going to be all but impossible I think, it is in there in such a fashion! There must be a way, I won't leave it that way but to make it driveable safely I did what I had to do, isn't that the true spirit of NASCAR country?
I agree with you, I would never buy a vehicle that looked patched together and would never sell one that looked that way either.
Thanks for reading!
Old Jun 5, 2012 | 08:46 AM
jagular's Avatar
Don't knock zip ties. They are extremely cheap, very robust, easy to instal, reliable and simple to remove. They also make convenient handcuffs for those in authority!
A nylon zip tie not exposed to UV degradation will last for over ten years. You'll find them all over a modern car, from the factory.
xjrjag
Nov 27, 2025 09:16 AM
SD96XJ6L
Jan 12, 2022 04:30 AM
X_Type_South_Africa
Dec 9, 2015 05:37 PM
MC36
US Lower Atlantic
Sep 1, 2015 07:34 PM
DaveInVA
Aug 31, 2015 08:12 PM
