Changing Belts Need advice. Thxs
Subscribe
Jan 21, 2024 | 10:39 AM
Hi everyone, Happy new year. Changing my belts can you confirm this will work. I do not want stock belts, better made aftermarket.
1 https://www.partsgeek.com/catalog/20..._rib_belt.html ContiTech Multi Rib Belt - Alternator and Air Conditioning is this correct ???
2 https://www.carparts.com/details/Jag...B&gclsrc=aw.ds SUPERCHARGER belt ? is this also correct ?
3 Anything else I should change while I'm at it ?
2015 Jag XF v6 Super charged 55k miles.
thanks Jayson this group is great !
Reply 0
Jan 21, 2024 | 01:49 PM
Have the plastic cooling parts been replaced?
How about the water pump?
Reply 0
Jan 22, 2024 | 01:00 AM
I have never replaced any plastic parts? I didn't know, Please will you direct me on what I should replace, Web Links, Names etc Please.
and No water pump replacement yet. but please Direct me on this also with a link. I will buy whatever i need. Sorry new to this and would like to keep my car nice. pulleys ? also ?
2015 55k miles S/c Stock V6
thanks Jayson
Reply 0
Jan 22, 2024 | 02:40 AM
The Gates SC belt is the correct one, can't confirm the Conti serpentine belt but it appears correct.
Reply 0
Jan 22, 2024 | 09:07 AM
Well a simple search will bring up dozens of plastic cooling pipe problems?
It's all been well documented and if you can't DIY any repairs plan for an expensive day!
Here is the result of a quick search of the forum for "Plastic Cooling Parts".
It returned 499 threads! It's up to you but really consider replacing ALL the factory plastic crap with the nice after market Alumnum parts?
Plastic Cooling Parts And The Failures
Reply 0
Jan 22, 2024 | 01:00 PM
Quote: Well a simple search will bring up dozens of plastic cooling pipe problems?
ok I will start working on this. what about vaccume lines ? when should i replace them ? your link did not bring up any pages just gives an error ? could you please fix
Reply 0
Jan 24, 2024 | 06:47 AM
This will give you a guide to keep your car reliable, (cooling pipes)mines 9 years old and runs brand new
Reply 0
Jan 24, 2024 | 07:55 AM
Sorry for the bad link!
Try this one?
Plastic Cooling Pipes
I have not replaced any vacuum hoses yet.
Reply 0
Subscribe
Currently Active Users (1)
