Charging at 15volts
Old Mar 21, 2025 | 04:06 AM
Giles Greenwood's Avatar
Default Charging at 15volts
I have problems with my 2012, 2 2 diesel and have observations here.
Intermittent hand brake and stability drop outs. Handbrake does work and things reset each time. The actuator drives to the service position ok
Engine goes into limp mode most days. Reader says imbalance on airflow, but replaced airflow and pressure sensors, still the same.
Maxi diag says GWM gateway fault and PAM parking assist control module fail.
Could the battery cause this? There is a permanent battery fault indicated on the reader sometimes?? Don't know if the battery has been changed and registered to the system, its a new car to me.
Any help appreciated.
Old Mar 21, 2025 | 08:18 AM
dennis black's Avatar
20 Year Member
If it's a new car, it may have sit on a lot for a while and the battery drained, then they jumped it without doing a battery reset, I would replace the battery, in this case to get a new start ,and have it reset with SDD PREFRABLY AT A Dealer then go from there, or if you have a icarsoft v3 you can go that route
Darve62
Apr 24, 2024 05:02 PM
Rlkessler19
Aug 29, 2022 12:15 PM
Jody Harms
Nov 9, 2020 08:00 PM
robbing
Dec 4, 2016 02:31 PM
nasa25
Apr 21, 2014 09:16 PM
