Clicking sound from Fuse
Old Nov 5, 2019 | 10:00 AM
MarkBishop's Avatar
Default Clicking sound from Fuse
Hello all
My XF S V6 Diesel has had a little turn at the weekend
Got in an pressed the "On" button and there was a handbrake error on the dash, car did not start...then it died nothing at all..all dorrs open and boot was shut had to use the key.
Left the car for a couple of hours and still nothing, smart key now stuck in the "keyholder thing" and there was a clicking coming from the fuse box in the boot
Rightly or wrongly I unconnected the battery and nothing and recommend still the same.
Car stuck on the drive now...any ideas ?
Mark
Old Nov 5, 2019 | 04:56 PM
John Williams's Avatar
Fully charge the battery, see if this brings things back to life
Old Nov 6, 2019 | 06:33 AM
MarkBishop's Avatar
Thanks will do, just unsure if I need a new relay switch
Old Nov 6, 2019 | 09:55 AM
lotusespritse's Avatar
When you don''t hear clicking, that's when you need a new relay switch.
Old Nov 7, 2019 | 06:47 PM
BritCars's Avatar
The click click is the central locking. Either didn't lock properly or got stuck in a cycle of lock / unlock and it keeps doing that until battery is totally dead. Saw that once before.
Disconnect battery fully. Charge it up (it will be very dead...). And assuming it recovers ok then reconnect and you should be fine. Prob need to reset window open/close limits (easy to do, search on here)
Assuming battery recovers then that's all you need.
Old Feb 27, 2021 | 07:08 PM
Louis Hart's Avatar
Hello all
Mark
was this ever resolved?
Old Mar 1, 2021 | 03:21 PM
davetibbs's Avatar
Low or failing battery can (and does) cause clicking noises, because as the voltage level gets low enough it causes the various modules in the car to reboot, which in my case caused the fuel filler flap motor to constantly lock/unlock. This is also what causes a multitude of errors related to transmission/ESC/ABS etc as these modules rebooting as the voltage gets too low causes errors on the network and fault codes. Charge or replace it.
LarMan
Apr 28, 2025 04:06 PM
paul stinton
Mar 28, 2019 04:20 PM
Zorro
Oct 18, 2018 10:50 PM
John Fox
Jun 14, 2018 03:11 PM
rtcosic
Jun 7, 2017 12:07 PM
