Coolant Leak
Old Jan 17, 2018 | 11:50 PM
Twiztidunreal's Avatar
Default Coolant Leak
When I took my car to Eurocharged to get the pulley and tune, they showed me a coolant leak I have. It seems to be right under the throttle body. What is this? The thermostat? or water pump?
Old Jan 19, 2018 | 01:21 PM
Adam J's Avatar
that's the water pump. thermostat is not shown in pic.
also, there is another hose that connects at bottom of throttle body (from rear crossover) that could be the culprit.
Old Jan 20, 2018 | 02:04 PM
Bigg Will's Avatar
Not a hard DIY
https://www.jaguarforums.com/forum/x...change-189069/
Just take your time.
Old Jan 21, 2018 | 07:37 PM
does the water pump sound like a bad bearing when it goes bad? like in my video below? i also see the pulley wiggling
Old Jan 22, 2018 | 04:28 AM
Bigg Will's Avatar
LOL, on a 10 to 1 count down to failure, your WP is at 2. Just know if you overheat a Jag AJ133SC due to a failed WP, you'll need head gaskets too.
Old Jan 22, 2018 | 05:42 PM
davetibbs's Avatar
Lol yes, get that pump changed out now.
Old Jan 22, 2018 | 06:33 PM
so SC has to come off to change the plastic tube? can the water pump be changed with out that being replaced? how many hour job would you say?
I actually have the extended warranty but that's a $250 deductible, if I can do it my self for less, then I'm all for it.
Old Jan 23, 2018 | 12:09 AM
Bigg Will's Avatar
No the SC does not have to come off to do anything in changing the WP or plastic tube, I had my SC off to facilitate the replacement of the plastic crossover tube on the BACK of the engine.
You want to change the plastic tube and WP at the same time. If a $250 deductible is all that's holding you, back pay it and get it fixed now.
Old Jan 23, 2018 | 08:03 PM
mghirsch's Avatar
Don't know what engine you have, but if it is the 5.0, be sure to replace the plastic crossover pipe if you replace the water pump.
Old Jan 24, 2018 | 09:13 AM
got the pump and the little plastic snout that goes on the back of it, but not the whole plastic crossover. Going to do the replacement my self today. It wasn't the $250 that was holding me back, more the fact of the dealer said they would need the car for 2-3 days to fix it... when I can do it my self in a few hours. I don't want to be with out my car for that long, lol.
From what I see, the swap is pretty basic, like doing an alternator on a normal car, since this is belt driven vs timing chain driven.
Old Jan 24, 2018 | 12:10 PM
yup! looks a little bad i would say... lol
Z07Brandon
Jun 22, 2017 11:48 PM
Nee_the_Bogeyman
May 8, 2016 07:25 AM
chtp66
May 26, 2014 06:45 AM
wcbcruzer
Dec 4, 2007 07:19 PM
Nov 5, 2006 12:06 PM
