coolant recovery tank
Old Sep 8, 2020 | 11:43 AM
kenc's Avatar
Default coolant recovery tank
Sigh..................
After replacing EVERYTHING in the cooling system from the water pump to the rear crossover and every hose/pipe in between, I got the car on the road and everything is good except the damn float has sunk in the coolant tank. I guess 9 years was pretty good going for anything in an XF cooling system?
Rather than fool around with bits of foam under the float I think I'll replace the final piece of the cooling system that I hadn't.
There are a dozen different aftermarket tanks, can anyone recommend one that is as good as the OEM, if such a thing exists. I've heard dire warnings against URO but there's loads of others. If I can't get a positive recommendation I'll buy OEM.
Old Sep 10, 2020 | 03:52 PM
cclaypool1967's Avatar
I bought this one on Ebay 6 months ago and working great !
File Type: txt
Coolant jug.txt (138 Bytes, 75 views)
Old Sep 14, 2020 | 04:56 AM
Reead Boodhoo's Avatar
Ebay is your best bet. I got mine from ebay in January but not avail for sale nw. Am sure they still hv it..
Old Sep 14, 2020 | 01:14 PM
kenc's Avatar
I ended up buying off Rockauto, I fitted it this morning, seems perfect. Only issue was it didn't say it came with a cap so I bought one as well, and it did, so now I have three caps including the replaced one! $80 delivered with sensor and cap included.
BKSinAZ
Jan 25, 2021 10:45 AM
v1rok
Jul 14, 2018 08:25 AM
TheHilds
Jun 13, 2014 02:14 PM
one
May 16, 2014 02:12 PM
JDP
Jun 27, 2013 08:13 PM
