Did a drain and fill with Ford sp fluid
Old Jan 19, 2021 | 10:33 PM
Oxidizer2k's Avatar
Default Did a drain and fill with Ford sp fluid
Finally managed to do a drain and fill with Ford SP fluid I bought on Amazon. It was a lot cheaper than the ZF fluid. I was experiencing some weird shifting issues and the dealer wanted $1000 bucks to do the pan service. Before I went that route I wanted to see if changing some of the fluid out made a difference.
one of the issues I was experiencing was when coming to a stop I would get a harsh bump from 2nd to 1st gear. Next issue was going from 2nd to 3rd it would almost feel like the transmission was slipping.
After watching some videos on YouTube on refilling the transmission, I was ready to give this a shot.
Not bad for 12 qts
Used this to raise the sides so I don’t damage the pinch rails
All four wheels off the ground and car as level as possible
Very tight space. Used stubby 8mm wrench purchased on Amazon.
Fluid was very dirty.
Used this fitting so it would hold itself in the fill hole
Used this to pump the fluid in
Worked very well
I didn’t do any adaptations with sdd since I don’t have it. I drove it normally for about 50 miles the. Parked it for a few hours. Then later at night took it back out. All my weird shifting issues have disappeared. The transmission is shifting very nicely and feels like it’s more crisp than before. I was a little worried about having too much or too little fluid inside but the transmission feels so much better than when I bought it. It currently has 73k miles.
Naso--Lituratus
Mar 3, 2015 06:22 PM
NTL1991
XJ40 ( XJ81 )
Oct 5, 2013 04:11 PM
AaronD81
Nov 8, 2012 10:38 AM
yeeran
Dec 5, 2011 03:11 AM
Reverend Sam
Apr 18, 2011 11:41 AM
