Doing the big plastic replacement!
Old Oct 28, 2023 | 11:36 AM
  #41
pdupler's Avatar
You can look up "sidewinder" ratchet or rotator ratchet on Azamon. Either version you twist the handle, it drives a shaft and gear that spins the anvil. But because the engineers at Jaguar never conceived of the rear crossover tube having to be removed with the engine in-situ, they spec'd those damned torx headed screws. Besides being very fiddly to keep a small torx bit engaged when its in such a tight, inaccessible spot, another issue is that as you back them out, the ratchet head gets closer and closer to the firewall, eventually too close. If you don't have a very thin headed ratchet and/or a short torx bit, you won't have enough room to back it all the way out. If you can get the torx screws out, don't even try to put them back in. Going back together, I went to the hardware store and got some standard hex headed cap screws, no flanges or anything. That way I could use a standard socket and the hex head would just ride up further into the socket as the bolt was backed out. It was a lot less fiddly going back together and will certainly be easier on the next poor slob who owns it at the second ten year interval, time for the next "big plastic".
Old Oct 28, 2023 | 02:10 PM
  #42
GabrielXJ308's Avatar
Default Hell yea
I put the same ones back in I bought the smallest ratchet and shortex torx 30 I could find took me a while but I go it and been driving the car. No leaks baby!!! So many plastic hoses and bs . Dumb engineers.. who does that🤣 glad it's done with the forums help thank u guys this Jaguar forum is the shiiii.
Old Oct 29, 2023 | 02:07 PM
  #43
lotusespritse's Avatar
Originally Posted by GabrielXJ308
What was the ratchet that you used
Both of these should be in your toolbox, not just for these coolant pipes.
Amazon Amazon
Amazon Amazon
Old Nov 2, 2023 | 03:48 PM
  #44
nsl1's Avatar
Did you replace the hose under the intake manifold. If yes - How did that go?
Old Nov 3, 2023 | 12:53 PM
  #45
Are you talking about the plastic pipe between the water pump and the engine oil heat exchanger? If so, that's easy once you take off the water pump, especially while you have the intake off. The rubber hose is easy too, but less of a concern than the plastic pieces.
Old May 15, 2024 | 10:23 AM
  #46
Bagherra's Avatar
There is definitely an opportunity here - especially at the date of this post. I have performed this on my 2012 XF 5.0 and this post was invaluable!
Thank you for the original post! Follow his lead to the T.
Old May 15, 2024 | 03:51 PM
  #47
2010XFPushBrakeHarderToStart's Avatar
Does this writeup also apply to the 4.2 NA engine?
cjd777
Mar 29, 2016 08:58 PM
Audio/Visual Electronics
Jul 5, 2010 02:25 PM
Jan 7, 2008 09:43 AM
XJ40 ( XJ81 )
Dec 10, 2006 09:05 PM
Oct 30, 2006 11:24 PM
