dome Light not coming on when opening door
Old Feb 11, 2013 | 03:57 PM
Gabriellus's Avatar
Default dome Light not coming on when opening door
Hi everyone,
I recently noticed that every-time a get in the car the dome lights (ambiant lights) don't light up. I have to physically touch the center light on the ceiling to open them.
Does anyone know why this is happening? Is this an option I need to set up? They were working a couple of days ago..
thanks,
Gab
Popular Reply
Feb 11, 2013, 05:24 PM
hlgeorge's Avatar
hlgeorge
Next time you get in the car, touch the center light and hold it for at least 2 seconds. Now try and see if it works. It may have accidently been turned off.
Old Feb 11, 2013 | 05:24 PM
hlgeorge's Avatar
Old Feb 12, 2013 | 09:30 AM
Gabriellus's Avatar
Thanks hlgeorge,
That did it lights are back to normal.
Regards,
Gab
Old Dec 22, 2017 | 03:30 AM
Vava-vooom's Avatar
Originally Posted by Gabriellus
Thanks hlgeorge,
Regards,
Gab
I have the same problem ...I will try it when I come home from work. Thanks for the tip. 😉
Old Feb 11, 2018 | 01:00 AM
Posnett Luke's Avatar
Got it , wow your a geezer 👍 thank you
Old Feb 16, 2018 | 10:35 AM
Jon Dean's Avatar
Worked for me, been living with it for about 9 months
All for 2 seconds.
Great tip.
Jon
Old Feb 18, 2018 | 06:14 PM
jmbpharris's Avatar
Default Great Solution
Just had the same issue with the overhead light. Came to the forum to research and surprised to find it was a current topic. The fix worked.
Thanks,
Jim
Old Mar 19, 2018 | 05:02 AM
MOHI's Avatar
Thumbs up Great help
Had the same problem,solved,thanks for the great tip,its miracle,
Old Apr 22, 2018 | 02:51 AM
sawkat's Avatar
Default Great,,,,
its also wirk for my jaguar xj model ,
Old Jun 17, 2018 | 04:01 PM
Mr5Stars's Avatar
Originally Posted by hlgeorge
next time you get in the car, touch the center light and hold it for at least 2 seconds. Now try and see if it works. It may have accidently been turned off.
thank you! Thank you! Thank you! MY 2014 XJL interior lights and rear sun shade screen were dissabled some how at the same time, I thought "Electrical Gremlins" were starting to take over my beautiful car
Old Jun 18, 2018 | 01:07 PM
hiltoncam's Avatar
The feature of turning off the interior lights by holding down for 2 seconds is to protect the battery when technicians are working on the car and require the door or doors to be open for a long time. Sometimes they forget to turn the auto on feature back on and that's when you notice your interior lights and puddle lights don't work.
Old Sep 22, 2018 | 07:08 PM
Apache88's Avatar
HI,
I have the same Problem, but it is in Auto mode and it doesnt works either.
When it schould lighten, it lights up for a second and goes off right away.
Help please
Old Apr 13, 2019 | 10:21 PM
Borisadog's Avatar
Default 2011 XF Courtesy Lights
Hi all,
I have a similar issue with my courtesy lights. However I also keep blowing fuses for the courtesy lights. My local Auto elec has told me it is beyond his ability as he believe is is somehow linked in to the cars computer system which he has no access to. I would really like to try and nut this out myself if possible and avoid the local Jag dealers labour rates. If anyone has had a similar issue I would love to hear from them.
Many Thanks
Old Apr 14, 2019 | 02:24 AM
John Williams's Avatar
Probably a short on one of the lights, I would start removing the bulbs one at a time until the fuse stops blowing, then you will know which light is causing the problem/short.
Old Apr 14, 2019 | 02:44 AM
Borisadog's Avatar
Thanks John,
I would never have thought a light globe could have caused such an issue. They are after all a form of fuse themselves. But I will definitely take a trip down this path to see what happens.
Old Sep 6, 2019 | 04:05 AM
Tom Brennan's Avatar
Thanks mine stopped for no apparent reason but would all work individually thanks
Old Oct 7, 2019 | 01:38 PM
daphil39's Avatar
I had the same issue. I followed your advise and it worked thank you so much. I thought it was a fuse or electrical problem.
Old Nov 23, 2019 | 08:14 PM
marinin41's Avatar
Default Thanks!
Spoiler
Old Feb 4, 2020 | 03:52 PM
Sarge04's Avatar
Thanks hlgeorge, my wife had the same problem with her dome light. I had to talk her through the process a couple of times and it works I've been trying to figure this out for almost of year...Appreciate it. Sarge
Old Jul 26, 2021 | 09:27 PM
Mauricesmith912's Avatar
Default Still not working
Hi, I tried the center light thing and while I'm in the car it will work. I turn the car off get out lock the door. I'll wait 15 seconds and unlock the door and again the interior lights won't come on. Do I have a bigger issue here?
