Driver Seat Control Module- Does it need to be flashed/programmed?
Old Apr 19, 2019 | 09:57 AM
Johnny Vig's Avatar
Default Driver Seat Control Module- Does it need to be flashed/programmed?
I like many others have a bad power seat module. I bought a used one that fits my 2010 XFR, which is a 18 way power seat module. Mechanic is stating he is getting a vin error when his non-dealer diagnostic tool is reading the module. It won't function at all. Does anyone know if this seat module has to be re-flashed with my car's vin number or do I need to buy a new module and have it flashed to my car? I can't get a straight answer from the dealers I speak to. One told me they will flash the used one I have, the other dealer stated the vin is burned in and I have to buy a new part which can then be flashed to my car because it wasn't flashed to a previous car. If anyone knows let me know- simply put is it a part that needs to be programmed to the vehicle and not just plug and play like other modules/parts. Thanks.
Old Apr 21, 2019 | 06:47 PM
davetibbs's Avatar
Yes, the driver's seat control module is VIN-coded, but I thought nearly all of the modules like this can be recoded with a new VIN - either with the SDD and a cable or one of the more advanced/equipped code readers that supports dealer functions (I have an Autel DS808 that does this). I'm sure there are exceptions but I can't think why the driver's seat module would be one of them.
Incidentally, the reason the driver's seat module is VIN-coded at all is because it needs to connect to the canbus in order to receive the signals when the "seat memory" button is pressed - these are sent on the canbus as they're also used to reposition the mirrors. Obviously, because the passenger seat doesn't have memory positions, it doesn't need (or have) a coded control module.
Old Apr 22, 2019 | 07:39 PM
lotusespritse's Avatar
Really? Like how many is many others?
Maybe I missed something, but I didn't think this was a common failure, as in many of us.
Old Apr 26, 2019 | 12:06 AM
Johnny Vig's Avatar
To clarify, many older jaguars had this issue, I don't know how many later model 2010 and newer cars had the issue. That said I got word from someone who spoke to a Tech at Jag HQ in New Jersey and they stated the module is hard coded with the vin of the vehicle and you can't use a used one in place of a new one that ultimately has to be flashed. I got a good deal on a new module and hopefully I have it successfully installed next week.
Old Apr 27, 2019 | 01:24 AM
JagV8's Avatar
The good news is that if this is indeed common then Search will get lots of other posts - usually with fixes. Let us know what you find!
Old May 10, 2019 | 08:54 PM
Johnny Vig's Avatar
Quick update- the seat is now fixed and although I put in a new seat module, the seat switch itself was the issue. Also turned 126k miles on my car today, still love it.
car5car
Mar 1, 2019 06:05 AM
Charbinjr
Aug 5, 2017 04:57 PM
Marni94
Jun 5, 2016 01:10 PM
JagCoast
May 11, 2015 07:43 PM
androulakis
Feb 20, 2010 03:13 PM
