Electrical Shut Down
Old Jun 18, 2020 | 08:39 AM
Dmatson57's Avatar
Default Electrical Shut Down
Hello all, I have been having a re-occurring issue and it is getting more frequent. My 2012 XFR 5.0 Supercharged just randomly losses all electrical power and leaves me coasting to a stop. It is unsafe to drive for fear of it shutting down in the middle of a merge or something. I have checked all the Power Cables and Fuses. Everything is tight. There is no wear on any wires. After about 5 minutes to an hour I am able to start the vehicle right up and it runs fine but all memory in the system has been reset. Any Ideas? I have searched the other threads and tried those ideas but nothing works.
Old Jun 18, 2020 | 09:57 AM
JagV8's Avatar
Could be anything from a loose wire (presumably to do with the ignition) to a fault that gets data logged but you'd need SDD to read.
Old Jun 18, 2020 | 11:29 AM
davetibbs's Avatar
How old is your battery?
Old Jun 18, 2020 | 01:30 PM
Jssaab's Avatar
^^^^ this
Old Jul 26, 2021 | 08:05 AM
Dmatson57's Avatar
Problem Fixed:
OK so its been a while and I finally found and fixed the problem. I tried everything from buying a new battery to calling the Jag Dealer (who was no help at all).
It started running fine again for a few days then left me dead in the road with no warning.
When I opened the trunk with the key to check the fuses I heard a small electrical actuator somewhere which meant i had power to something from the rear fuse box.
**What I am going to say now is not recommended but I was stuck and frustrated.**
I took my Jumper-cable and bypassed the rear junctions terminals and hooked straight to the top of the front fuse box under the passenger kick panel.
I immediately had power and was able to start and drive all the way back to the house.
After that I replaced the High Amp Fused going from the Junction tot he Front Fuse Box which cost me only $5 online.
Haven't had the problem since then. Not sure why it worked some of the time and then all of a sudden go out.
My best guess is maybe the element was separating when it got hot causing the random shut downs.
I never saw the High Am p Fuses before because they are tucked away in the trunk under carpet further back behind the rear quarter panel.
petes76
Sep 11, 2019 01:25 PM
webshark
Dec 4, 2017 12:14 PM
Fast Cat
Oct 22, 2014 10:25 AM
ormy49
Nov 14, 2012 05:49 PM
spuds1956
Sep 24, 2010 04:15 PM
