Jaguar XF BOOT
Old Jul 24, 2021 | 10:30 AM
Liam C's Avatar
Default Jaguar XF BOOT
Hi Guys, This morning I have noticed an issue with my XF 08 Jag.
The boot will not open. I have tried so many methods to try and get it to open but it just will not open. I have also tried the manual key putting it into the slot but still nothing.
Now, When you press the boot button, you do hear like a buzz noise and you also see on the dash "boot open" but that then soon goes when you take your finger off.
Please someone shine a light here because I don't know what has caused this or how to get this to open
Thankyou!
Old Jul 25, 2021 | 04:44 AM
fivel's Avatar
Thankyou!
It's odd that you can't open it with the key, the electronic latch release sometimes fails, but you can always open it with the key since that is mechanical. Does the key turn at all?
The lock can be very stiff because its never used. I had to blast a bit of WD40 into mine to get free it up since it hasn't been used in a decade. You have to make sure the key is the keyway properly, it's actually quite fiddly to get it in the right place with the small shank of the key.
Old Jul 27, 2021 | 05:20 AM
Liam C's Avatar
Just an update, I've managed to get into the boot with my manual key!
However boot wont open with fob or car boot button.
Is this the loom that needs replacing or something else?
I have run my IcarSoft and it comes up with this error:
Error: B113E
External Luggage Compartment Release Switch
Old Jul 27, 2021 | 07:42 AM
fivel's Avatar
The 2 likely faults that can cause this are either
  • the wiring loom in the trunk hinge has broken and the release signal isn't getting to the latch
  • the latch is broken
Both are common faults on a car this age.
Unplug the connector to the latch and see if you can see a release signal at the latch (I think it's pin 1, but check the wiring manual). If there's no signal its probably the trunk lid harness in the hinge. If there is 'open' signal received then the latch motor is probably bust.
Old Jul 27, 2021 | 08:11 AM
Rummy636's Avatar
You could check the loom and almost guaranteed to have a cut/broken wire. Either repair the wire or IMO replace the jumper harness.
Maverick76
Jul 24, 2023 06:52 PM
TonyScowen
XF (X260)
Mar 11, 2021 10:32 AM
joebit
Oct 24, 2020 04:11 PM
MClarky
XF (X260)
Oct 23, 2019 11:59 AM
Andy Hill
Sep 7, 2019 06:05 AM
