Engine Compatibility
Old Aug 30, 2021 | 09:42 PM
kelster's Avatar
Default Engine Compatibility
Can someone tell me if a 2014 Jaguar XKR 5.0L supercharged complete engine assembly
8th VIN C will fit into a 2011 Jaguar XFR 5.0L Supercharged 8th VIN C?
Old Sep 1, 2021 | 11:26 AM
kelster's Avatar
Default Followup
Does anyone have a response?
Old Sep 1, 2021 | 12:38 PM
IanXF's Avatar
should fit without any problems
Old Sep 1, 2021 | 04:10 PM
Swilmer52's Avatar
You will have to swap the old supercharger assembly to the new engine, due to the original supercharger being vacuum actuated compared to the newer electric actuator.
Old Sep 5, 2021 | 02:43 PM
davetibbs's Avatar
As Swilmer mentions, the supercharger.
Keep the ECU/wiring loom from original engine and fit it to new one, becuase the newer engines have different ECUs. In any engine swap like this you always want to retain original electronics and swap mechanicals.
The only other thing you may need to keep from the old engine is the 4x VVT solenoids that screw in front of the camshafts, as the connector style changed on later ones. You can get adapter looms (part number is in a TSB) but they're a bit of a PITA.
Other than that I'm not aware of any material differences - I believe engine block design is the same etc even with the 8 speed transmission in later models but if anyone knows different I will defer to them as I haven't spent a lot of time with the newer block.
Mark Murphy
Jan 25, 2018 03:28 AM
Jamgate
General Tech Help
Nov 20, 2017 02:44 AM
metalman88
Dec 9, 2014 04:13 PM
toronadomike
Dec 8, 2013 10:45 PM
Hayk Brsoyan
Oct 27, 2012 11:22 AM
