2001 S type 4.0 engine swap VIN question
Old Dec 9, 2014 | 11:54 AM
metalman88's Avatar
Default 2001 S type 4.0 engine swap VIN question
hello, I have a 01' 4.0 S type with a rod out the side of the block. I am researching replacement motors, blocks, ect and I keep running across a VIN reference that the 8th digit VIN change between a "D" and a "P" means the engines are not interchangable.
The only information I have found on the forum is that there may have been a flex-plate / torque converter change sometime in 01' .
Can anyone confirm this, and are there any other engine changes between the "D" VIn and the "P" VIN ?
thanks !
Old Dec 9, 2014 | 12:10 PM
abonano's Avatar
I believe there is a VIN cut off sometime within the 2001 MY (not sure) Research used engines on EBay - the info you need to reference is the last 6 of your VIN (LXXXXX) to be 100% sure. The engine you need would have a "P" as the 8th digit of the VIN.
Do not plan on installing a 4.0 from a XJ8 - is not comparable.
Be wary with these used engines - they are essentially "ticking time bombs" unless tensioners/guide rails are changed out, otherwise you'll be wasting your $ Look to spend minimum $1,200 (I'm being optimistic - cost will be actually higher) and up for a used high mileage engine w/ NO guarantees...
Old Dec 9, 2014 | 12:38 PM
metalman88's Avatar
thanks Abonano, my goal is to get a time bomb that hasn't exploded yet for a resonably low proce and then rebuild it before swapping it in.
I am just wary of the VIN change as i don't know what it means with regards to the motor changes.
Old Dec 9, 2014 | 04:13 PM
abonano's Avatar
If you do get a used engine - just have the tensioners and chains/guide rails changed out. Much easier job when the engine is out. That should give you good life out of the engine for sure.
stanjag
Dec 29, 2024 08:26 PM
celticpiping
Sep 18, 2015 06:17 PM
SatanClaus
US Southwest
Aug 31, 2015 11:45 AM
SatanClaus
Aug 29, 2015 09:15 AM
dpappyp
Aug 27, 2015 06:31 AM
