2001 S type 4.0 engine swap VIN question
hello, I have a 01' 4.0 S type with a rod out the side of the block. I am researching replacement motors, blocks, ect and I keep running across a VIN reference that the 8th digit VIN change between a "D" and a "P" means the engines are not interchangable.
The only information I have found on the forum is that there may have been a flex-plate / torque converter change sometime in 01' .
Can anyone confirm this, and are there any other engine changes between the "D" VIn and the "P" VIN ?
thanks !
thanks !
I believe there is a VIN cut off sometime within the 2001 MY (not sure) Research used engines on EBay - the info you need to reference is the last 6 of your VIN (LXXXXX) to be 100% sure. The engine you need would have a "P" as the 8th digit of the VIN.
Do not plan on installing a 4.0 from a XJ8 - is not comparable.
Be wary with these used engines - they are essentially "ticking time bombs" unless tensioners/guide rails are changed out, otherwise you'll be wasting your $ Look to spend minimum $1,200 (I'm being optimistic - cost will be actually higher) and up for a used high mileage engine w/ NO guarantees...
thanks Abonano, my goal is to get a time bomb that hasn't exploded yet for a resonably low proce and then rebuild it before swapping it in.
I am just wary of the VIN change as i don't know what it means with regards to the motor changes.
stanjag
Dec 29, 2024 08:26 PM
