Is the engine cover necessary?
Old Aug 19, 2015 | 01:48 PM
  #121
jagular's Avatar
Originally Posted by damienedwards
Have another guess........
Henessey have allready produced a 650hp conversion for the 5.0 S/C.
I can only find the 623 bhp version with 568 lb ft of torque. And require 93 PON gas to get there, stock only requires 91.
Also, it's not quicker than stock, although the F Type R does suffer a bit from traction issues.
Hennessy claims to improve the intake and intercooling and fit an under drive pulley.
Old Aug 19, 2015 | 05:04 PM
  #122
damienedwards's Avatar
Its got more power and its no quicker than stock.........i am thunderstruck.
Intake improvement is 4x 38mm holes in each airbox..................
Old Aug 20, 2015 | 08:25 AM
  #123
jagular's Avatar
It's just the way supercharging works:
Watch Hennessey's 623-hp F-Type R Lay Down a Scorching 1/4-Mile ? News ? Car and Driver | Car and Driver Blog
Hope this helps resolve your confusion.
Old Aug 20, 2015 | 12:13 PM
  #124
Confusion is with you i'm afraid.......
Only a complete dufuss would make a blanket statement like that, not comsidering for one second the many variables involved......
there again that may explain a few things.....
Old Aug 21, 2015 | 11:18 PM
  #125
n8ertot's Avatar
So back to the matter at hand... I took a pic of the engine to post in another thread. Thought I'd put it here too. Since starting the thread, I removed the engine cover and associated insulation and also shortened the resonators. I'm pretty happy with the results (although I haven't prettied up the resonator change yet.
Old Aug 22, 2015 | 09:06 AM
  #126
DPK's Avatar
DPK
I'll have to say that looks pretty damn good..I think more so on the SC engine...Why hide that thing of beauty?
Old Aug 22, 2015 | 10:19 AM
  #127
n8ertot's Avatar
Right?!?!?! I sorta want to paint the central part, but not sure I'll ever get around to it, partly because I don't know what color I'd go.
Old Aug 22, 2015 | 11:29 AM
  #128
DPK's Avatar
DPK
I've seen folks with similar set-ups..go with the color of their car for that center portion..Just a thought.
Old Aug 22, 2015 | 10:55 PM
  #129
n8ertot's Avatar
Yeah, but black seems like it would just make it look like more plastic.
Old Aug 22, 2015 | 11:20 PM
  #130
2010 Kyanite XFR's Avatar
Default Is the engine cover necessary?
If the car is black then pick your favorite color and don't look back. Everything goes with black. And if you decide you don't like it just put the cover back on!
Old Aug 23, 2015 | 07:35 AM
  #131
jackra_1's Avatar
Default I chose gloss black
I chose gloss black for my 2005 XJR. I have a leaping Jaguar stencil on order, from the U.K, and intend painting it red on the gloss black. I am supposed to be working on house projects and do this instead when I cannot bring myself to start on the house projects.
Attached Thumbnails Is the engine cover necessary?-p1060873.jpg   Is the engine cover necessary?-p1060874.jpg
Old Aug 23, 2015 | 12:04 PM
  #132
Jackra,
that looks fantastic!!! Unfortunately the 5.0 supercharged engine is not quite as astheticaly pleasing as the 4.2.......
good job fella
Old Aug 23, 2015 | 05:07 PM
  #133
n8ertot's Avatar
I have the 4.2 as well, but mine doesn't have the nice smooth sides and "supercharged" across it that would make it look that good when painted. The cooling fins on mine would make it nightmarish to paint as well, so about the only place I could paint would be the top center intake housing. Maybe if I did the jaguar stencil like you're going to, it would look good, but for now I don't think mine would look as good painted black.
Old Aug 23, 2015 | 06:53 PM
  #134
jackra_1's Avatar
So long as the stencil is the size I think it is I will post a pic when its done.
Old Aug 29, 2015 | 01:32 PM
  #135
jackra_1's Avatar
Default Stencil arrived
This is how it looks. Still have a bit of touch up to do. Used paper glue to stick the stencil down as the curved surface was a little difficult to work with as the stencil was overhead transparency material.
Attached Thumbnails Is the engine cover necessary?-p1060877.jpg   Is the engine cover necessary?-p1060876.jpg
Old Aug 31, 2015 | 12:52 AM
  #136
n8ertot's Avatar
That looks pretty damned good. May have to work on something like that. Thanks
Forcedair1
Sep 8, 2025 01:57 PM
dsnyder586
Dec 29, 2024 07:39 PM
XJsc-guy
Sep 25, 2015 11:09 AM
KarimPA
Sep 12, 2015 08:15 AM
KarimPA
Sep 3, 2015 07:32 PM
