Engine Knock on Startup? (Video)
Old Aug 1, 2015 | 07:32 PM
hen555's Avatar
Default Engine Knock on Startup? (Video)
Sometimes when I start my XF I hear a knocking noise. I just hear 1 knock as if some metal is hitting and then the engine starts. It usually happens during crank and usually it happens when the engine starts quickly as opposed to longer cranking of the engine with the starter.
Luckily when I was recording my exhaust (as I have never heard what it sounds like from the back) I heard the knock noise. I got it on video and although it is hard to hear you can still hear it at the 0:08-0:09 mark after the engine has started with its rev blip.
Usually when I try to reproduce the problem by turning the engine off then on again the noise doesn't occur. Maybe it is only possible during a cold engine start.
Also do keep in mind this is a replacement engine I got recently in which the jaguar service did not tell me anything about how to break it in. Maybe I need to change the oil since its a new engine and possible metal alloy pieces collected in the fluid?
Old Aug 1, 2015 | 08:01 PM
DPK's Avatar
DPK
Starter motor maybe loose..I've seen/heard something like this before after an engine replacement...the mounting bolts were overlooked and never tightened down during final re-assembly.
But I've said it before; I'm sorry to say but this dealership you're using, seems like idiots with the way they keep you coming back with issues.
Old Aug 2, 2015 | 09:19 AM
jagular's Avatar
Jaguar no longer specifies any running in time or requirements for a new engine. The first oil change required is at the same interval as for every oil change 1 yr or 24,000 km (I'm pretty sure the new 5.0 is 24,000 and not the 16,000 km applicable to the 4.2).
Nevertheless, it is good practice to treat a new engine with respect for the first 1,500 km or so. Three tanks of gas is long enough to ease a new engine into service. Then you should really demand full engine performance for the next three tanks at least in order to finish the break in properly. Mind you, I drive it that way all the time after break in, I can't help myself.
If you are concerned about noises take it back to the mechanic who installed the new engine, he wants to fix it.
Old Aug 2, 2015 | 09:42 AM
WRXtranceformed's Avatar
It looks like you have several threads going about the post-motor swap problems. It might be helpful to consolidate them into the original thread. Sorry you are having these issues but keep on the shop to make everything right. And after you are finished I would start searching for a new shop to be honest. It doesn't sound like these guys are on their A-game
Old Aug 2, 2015 | 11:04 AM
Mikey's Avatar
Sounds like the clutch on the A/C compressor to me.
Old Aug 2, 2015 | 01:01 PM
hen555's Avatar
Yeah I do but I am not entirely sure if this issue is related to the engine swap or just a failing part from before. But I can harmonize them if I know how to.
...after you are finished I would start searching for a new shop to be honest. It doesn't sound like these guys are on their A-game
I am highly considering that. The dealership also told me they don't like their customers going on forums. A service rep and mechanic there told me that because they said customers try and make them do things based on the forums. I don't understand whats wrong with suggesting things to them.
Anyways the problem about this issue is that it doesn't happen all the time. I cannot recreate the issue and thus when I tell those premium brand service reps or service manager my issue they will be like there's nothing we can do now if you cannot show us it (which I can understand...I guess).
I hate going back to these guys because of the poor service they give to me and they probably already see me leaving them as I complain to them all the time about their f-ups.
Old Aug 2, 2015 | 04:13 PM
Yeah man doing poor unfinished work, telling you they don't want you on the forums and damaging your car and leaving food in it? You are being way cooler about the situation than I would....I would blow them up in person, online and to JLR north America so hard that nobody would want to service their car there again.
Old Aug 3, 2015 | 12:22 PM
jagular's Avatar
Here's who owns Jaguar of Saskatoon:
New and Used Audi / Ford / Hyundai / Jaguar / Land Rover / Mercedes-Benz / Mitsubishi / Porsche / Smart / Volvo Dealer | , | Vaughn Wyant Automotive Group
You may have to travel to Calgary to get better service!
Old Aug 3, 2015 | 12:28 PM
jagular's Avatar
Not such a good idea up here. His nearest alternative is a 7 hour drive, one way.
Old Aug 3, 2015 | 05:49 PM
hen555's Avatar
Here is another video I shot today. I started it up on an incline engine fairly warm. The sound happened during engine crank this time. After startup you can notice the car shaking. What do you think? Note: you may hear 2 sounds...the one after is releasing the push button start.
SD96XJ6L
Jan 12, 2022 04:30 AM
JagBrian
Aug 18, 2019 05:07 PM
cissdm
May 3, 2016 06:02 AM
robiwhan
Sep 4, 2015 10:43 AM
Jaguar Forums Editor
Jaguar Press release
Sep 4, 2015 09:18 AM
