Engine oil
Old Feb 8, 2019 | 06:14 AM
Arne Riis's Avatar
Default Engine oil
When checking engine oil on instruments at my XF 5.0 it writes engine failure. Do you just renew the oil presure swich, or anything else ??
Old Feb 8, 2019 | 08:58 AM
lotusespritse's Avatar
Get a code reader and see what the ECU says about "engine failure"
That sounds really bad.
Old Feb 13, 2019 | 03:52 AM
Arne Riis's Avatar
Smile Engine oil
when testing with engine tester the message came out b100a and in an reference it said Number-plate- right sid fault. I knew that and had ignored it as an minor fault to be repaired next service. But anyway I fitted an new light and now I can measure the engine oil. Strange that these two faults is connected.
Old Feb 13, 2019 | 05:38 PM
Good job getting a code reader. When getting an error on the dash, it's always the first step before anything else, including posting to forums.
Aleather
Nov 23, 2018 02:20 PM
mgoldXK
Nov 17, 2018 11:00 AM
SableXJ6C
Nov 17, 2018 07:42 AM
Aleather
Nov 13, 2018 05:41 PM
Lotusjag04
Nov 12, 2018 05:17 PM
