Engine t/min unstable then dies while driving
Old Jan 24, 2021 | 05:12 AM
Yohan Herault's Avatar
Question Engine t/min unstable then dies while driving
hello, i'm searching for help.
I'm the owner of a jaguar xf s 3l v6 275hp 2009 with 110K miles.
Recently the engine start to misfire regulary, every 10 or 15 secondes the t/min is going down to 500t/min for 2 secondes and back to normal, like something block the air or fuel, while i was driving then dies. The car start again after then do the same process. misfire 3 or 4 times then dies. Even when not driving.
There's no warning or default light on the dashboard.
I bring it to the garage but the mecanics are unable to find where the problem is coming from. (i'm in France and the garage is not a Jaguar specialist...).
They change the gazoil filter but no good results. they said that it's might coming from the injection system but need to undo a part of the engine to check it with no guarantee of result..
Is someone able to give me some good tips that i can communicate to the mechanic?
Thanks !
Old Jan 25, 2021 | 09:00 AM
fivel's Avatar
Have you checked the OBD to see there are any DTC codes being thrown? I would expect to see a DTC if the engine is stalling out like that.
Old Jan 28, 2021 | 10:55 AM
JagV8's Avatar
They probably can't or didn't look for Jaguar-specific explanatory codes
Andreas Schmieg
Nov 12, 2017 07:29 AM
hqmok
Nov 30, 2013 10:40 AM
Gunnar Gabrielson
Dec 25, 2012 07:55 PM
tcbjaguarxjr
Nov 2, 2011 03:22 PM
nahidik
Oct 7, 2009 09:10 AM
