Exhaust questions
Old Nov 6, 2017 | 08:43 AM
cyndav6875's Avatar
Default Exhaust questions
Quick question does anyone have detailed information on removing the valves on the stock mufflers for an 09 Xf supercharged? Any experiences would be greatly appreciated thanks.
Old Nov 8, 2017 | 12:17 AM
2010 Kyanite XFR's Avatar
Are you sure the 09 had the valves? Mine is a 10 and I'm a bit ignorant as to whether the earlier version was so equipped.
If it does have the valves, just take it to a muffler shop. Have them cut the round bump on the end out, remove the valve components and then we'll the bump back on.
Craneboy was the originator of that on the forum as far as I know. I copied him including the x-pipe. Do a search for posts by him and you'll find the diagram to give the shop.
Old Nov 9, 2017 | 08:32 PM
Jim Miller's Avatar
Kyanite, how is the highway drone with your setup? It is X pipe, midmufflers and resonators removed, and valve delete?
Old Nov 9, 2017 | 11:44 PM
The only time I can say it's even close to a drone is when I'm going slowly up a steep hill. Otherwise, I believe it sounds like it should have from the factory. Just loud enough to hear it, but never intrusive...unless I'm really getting on it and then it's louder, but still mellow. For reference, I felt the stock note was pathetic and almost non-existent. More of a whoosh than anything else.
The x-pipe really killed the decel pops and crackles. I love that it did. Others seem to go out of their way to accentuate those sounds. To each their own. But I don't want my XFR to sound like the half-dozen Chargers I'll see in a day. Wanted something more refined. It now sounds more like a Maserati than anything American.
If you want your car to retain the gentleman's express character, I would copy my setup. If you want it louder and more raucous, change the mufflers. Another member had his exhaust done at the shop I had my work done at, and I have dibs if he's ever going to sell the car. It's not much louder than mine when driving normally, but really wakes up when on it. I think they used Magnaflows, but it's been a while since he put it on. He had an Arden he imported from Germany and it was entirely too loud. No way to use the Bluetooth and still have a conversation.
Old Nov 9, 2017 | 11:46 PM
10 XF Premium's Avatar
I have the 2013 5.0SC with the complete center section replaced with straight pipes, X-pipe (right before the dual pipes separate to go outward to the rear boxes), and the valves deleted from the stock V8 rear cans.
There is ZERO drone. None, nada, zip, period.
The x-pipe gives the tone a very European, high reving tone.
Old Nov 10, 2017 | 12:26 PM
Jim Miller's Avatar
I'm sold thanks guys.
Now the trouble is finding somewhere to take it here in Raleigh NC. The guy that I have used before closed up shop unfortunately.
Old Nov 10, 2017 | 04:32 PM
Just find someone who does custom exhausts for hot rods and can do good welds.
Old Nov 10, 2017 | 05:49 PM
OzXFR's Avatar
+1.
My exhaust bloke does exactly this, including hand made headers and extractors for drag cars and show cars, and several times I have watched him while he has fabricated custom stainless steel exhaust systems for me.
He's a real artist with the welding gear.
Old Nov 13, 2017 | 06:28 PM
cyndav6875's Avatar
Default More questions
Does anyone know if my 09 xf sc has stock muffler valves or not? Right now I have resonator delete going to stock boxes, too much drone. I am looking for a more muscular European sound inside and out? What will happen if I do and x pipe and rear box delete? Or should I do x pipe and magnaflows? As you have read I'm very confused in which direction to go? Thanks so much sorry so long.
Old Nov 13, 2017 | 09:48 PM
If you don't have the valves, just put the x-pipe on first. See if you like the tone and if it's too quiet, change out the mufflers. You may spend a little more doing it in two sessions, but you won't waste any money if you don't like the sound with the new mufflers and want to go back.
