Expansion tank stays full
Old Jun 16, 2024 | 01:28 PM
VetteOwner's Avatar
Default Expansion tank stays full
As background, my 2013 XFRS had the plastic bits, water pump and thermostat housing replaced back in March, 2023. The expansion/overflow tank has maintained the same level of mid point of the cold level indicators. Past month or so I’ve noticed the tank remains completely full up to the cap. Sitting overnight doesn’t change the level. There are no codes or dash warnings. Removed approx .5 liters of fluid but level hasn’t decreased. Hoping someone has suggestions.
Old Jun 16, 2024 | 02:06 PM
User 42324's Avatar
A guess: you have an air lock somewhere.
If you've taken 5L of coolant out then I'd say you're running seriously low on coolant.
Old Jun 16, 2024 | 02:18 PM
VetteOwner's Avatar
That’s .5 of 1 liter, Not 5 liters…thank goodness.
Old Jun 16, 2024 | 04:05 PM
User 42324's Avatar
Thanks. Another indicator to get my eyes checked.
So it's 0.5.
Old Jun 16, 2024 | 06:19 PM
DeviLSh's Avatar
I would try taking some more out and redoing the top off bleed sequence
otherwise, a full drain and vacuum fill
Old Jun 17, 2024 | 01:39 PM
lotusespritse's Avatar
More than a year later of normal coolant levels, and then you have an air pocket show up? Seems unlikely.
I would do a test for exhaust gases in your coolant to see if something else is going on. You could have a head gasket issue that is just now showing up and pumping air into the coolant system. Did you overheat your engine just before the cooling system parts were refreshed? Often, the cooling system refresh is done reactively to a coolant leak that could have caused overheating.
Old Jun 17, 2024 | 09:37 PM
dennis black's Avatar
Try a bleed if that doesn't work ,you may have a problem
Old Jun 22, 2024 | 03:48 AM
2010XFPushBrakeHarderToStart's Avatar
Apologies if this is a dumb question, but are you sure the additional volume is coolant? Got pics?
Old Jun 22, 2024 | 11:38 AM
VetteOwner's Avatar
I believe that it is as the color appears consistent. I removed the excess down to the cold level and, thus far, seems fine.
I have had 2 prior service visits unrelated to coolant so I have no idea where the excess fluids came from.
JACKP
Jul 25, 2023 01:42 PM
St. Stephen
Feb 5, 2023 05:36 AM
cityboy
Oct 20, 2021 09:21 AM
Ktmscott
May 23, 2019 02:47 PM
Bufford85
Aug 18, 2017 02:08 PM
