Fuse location
Old Oct 4, 2020 | 10:51 PM
Sprinkler's Avatar
Default Fuse location
Can anyone tell me where to find the fuse for the reversing camera on my 2010 XF?
Old Oct 5, 2020 | 07:51 AM
fivel's Avatar
I don't think its got its own fuse from a number of the rear electronics.
"The parking aid camera receives an ignition power mode 6 power supply from the RJB."
What problem are you having?
Old Oct 6, 2020 | 03:12 AM
hiltoncam's Avatar
Is the camera image not popping up or is it giving a blue screen?
Old Oct 7, 2020 | 08:01 PM
Sprinkler's Avatar
no camera image, all that shows is a picture of a car and a warning buzzer sounds when close to a hazard.
Old Oct 8, 2020 | 12:57 AM
hiltoncam's Avatar
I know this is a rather dumb question, but does your XF have a camera above the license plate? It sounds like your car wasn't fitted with one, only parking sensors. If it was fitted with a camera and the camera isn't working when you put it in R, you would usually get a blue screen pop up. Very odd that it doesn't even pop up when in R if you do have a backup camera. The usual culprit is the wire that runs from the body of the car into the trunk lid. It's on the right corner when you open the trunk. If you pull that concertina rubber cover back, you would find the broken wire or wires right there. They bend each time you close the lid and opening and closing bends it back and forth and that usually breaks the wires. If this is the case, it's easy to splice them back together and wrap some conduit tape around them to avoid it happening again.
Old Oct 8, 2020 | 03:28 PM
Sprinkler's Avatar
Good morning Hiltoncam. The car is fitted with the camera. I will have a look at the wire as you suggest.
Old Oct 9, 2020 | 01:23 AM
Bigv's Avatar
A front or rear parking sensor failure can knock out the camera too
Old Aug 20, 2024 | 06:04 AM
Martita76's Avatar
Default Reverse camera not working
mine is blue and I can't figure out what's wrong with it. It stopped working suddenly
jagadmirer
Sep 16, 2024 09:40 AM
OUScooby
Dec 31, 2019 09:48 PM
obwoodie
Dec 12, 2015 10:01 PM
mrtalkradio
XJ40 ( XJ81 )
Feb 24, 2012 05:36 PM
Sovereign_ty
XJ40 ( XJ81 )
Dec 30, 2007 06:40 PM
