Gauge Cluster fading in and out...
Old Oct 9, 2014 | 12:40 AM
RodTee XF's Avatar
Default Gauge Cluster fading in and out...
Have any of you experienced the electronic display between the speedometer and tachometer fading in and out?
Old May 11, 2015 | 02:54 PM
RodTee XF's Avatar
BUMP....has no one had this happened??
Old May 11, 2015 | 03:22 PM
chXFS's Avatar
Mine does too every so often. I don't know the fix.
Old May 11, 2015 | 03:59 PM
RodTee XF's Avatar
Thanks for the reply...was starting to think mine was the only one. Like you mine only does it every now and then but its annoying...
Old May 23, 2015 | 04:06 AM
fletch106's Avatar
Yes, mine did that. The fault lies within the cluster. It's not the electrolytic caps as I thought it could've been. Must be a surface mount component gone bad, but I'm not skilled enough to troubleshoot those (and not without a schematic from Visteon). Fixed it with a swapped cluster. You need to be good with SDD and a Mongoose cable to do key unprogramming, reset immobiliser and reprogramming of keys on the new cluster. Or pay the best part of £1000 to have Jag do it!
Fletch
workworkwork
Oct 23, 2015 10:26 AM
emilime75
XJ XJ12 ( X305 )
Oct 19, 2015 09:55 PM
vwbusbits
Oct 13, 2015 03:43 AM
mrplow58
Sep 30, 2015 08:56 AM
