Global Open?
Old May 13, 2015 | 05:28 PM
hlgeorge's Avatar
Default Global Open?
Can the XF be programmed for the key fob global open feature. My 04 XJ had it and I thought my current XF did too. Didn't work today, so I'm guessing I just was remembering the old XJ> (Kind of wish I still had that car!)
Old May 13, 2015 | 05:52 PM
jagular's Avatar
I think it can be selected in a vehicle settings menu but global close maybe not. I do know in the newer models it can only be operated from outside the car. I think global close requires you to press the lock button on the door if you have keyless entry, no fob option.
I agree the old system programmed to the lock and unlock buttons on the key fob and also available inside the car using the master lock and unlock buttons was a great feature but they changed it.
Old May 13, 2015 | 08:31 PM
allenman85's Avatar
Yes, as jagular says, the current XF's have it. It is a feature controlled in the touchscreen menu. Global close is by external door keypress only.
Old May 14, 2015 | 07:44 PM
hlgeorge's Avatar
THANKS! I knew that I had used it before. Must have been turned off at a dealer service. Just turned it back on and works great.
99xk8guy
Sep 29, 2025 10:51 PM
hoodun
Nov 20, 2022 02:35 PM
kabs3012
Sep 12, 2015 10:40 AM
findre
Sep 10, 2015 05:46 PM
kabs3012
US Midwest
Sep 10, 2015 01:17 PM
