Grille dimensions
Old Sep 4, 2015 | 01:46 PM
bigdhenderson's Avatar
Default Grille dimensions
Can anyone get me some measurements from their grille? Looking to do a custom bumper for my XKR using an XF or XJ grille, if it will work. Just need some measurements to see if it's even possible. Thanks!
Old Sep 20, 2015 | 07:11 PM
Just need an overall width and height, cam anyone get me these measurements please?
Old Sep 20, 2015 | 08:24 PM
OzXFR's Avatar
We need to know which model or date range of XF you are considering, as the post-2012 XF has a slightly bigger grille than the original XF.
Old Sep 20, 2015 | 08:48 PM
Either or, preferably both. Also looking for newer XJ grille sizes too
Old Sep 20, 2015 | 11:51 PM
OzXFR's Avatar
I've done a bit of trawling on the interwebz and I can't find any sizes.
The measurements on my 2010 XFR (so "classic" or "pre-facelift") are:
Top maximum width - 64 cm
Top corner to top corner - 62 cm
Bottom corner to bottom corner - 54 cm
Maximum height (middle top to middle bottom) - 25 cm.
Hope this helps!
Old Sep 21, 2015 | 05:48 AM
jaguny's Avatar
I have my oem grille that I replaced with a black oem in my garage, I can dig it out and get this for you. May take a day or two. It's a 2011. Will sell also.
Old Sep 21, 2015 | 08:15 AM
Hope this helps!
Thank you!!
Old Sep 21, 2015 | 08:17 AM
Hmm, I might be interested. Is it chrome? Let me cross check those dimensions and see if it will even work out for my project first.
Old Sep 22, 2015 | 10:11 PM
jaguny's Avatar
Yes it is chrome without the center logo. I can get measurements tomorrow, but should be the same as the 2010.
Old Sep 27, 2015 | 08:49 AM
jaguny's Avatar
25-5/16" wide x 10 " high
Old Sep 27, 2015 | 09:20 AM
That with the bezel?
Old Sep 29, 2015 | 05:23 AM
jaguny's Avatar
That''s to the outer chrome trim (I believe you are referring to the bezel) at itsome widest points.
Old Sep 29, 2015 | 05:29 AM
jaguny's Avatar
Photo attached
danke
May 29, 2023 01:01 PM
Quantico
Oct 13, 2015 10:34 PM
XJ8JR
Sep 29, 2015 06:59 PM
Blake04VDP
Sep 28, 2015 05:20 PM
