Help with bi xenon lights
Old May 8, 2011 | 12:38 AM
hawee's Avatar
Default Help with bi xenon lights
Hey Guys,
I just purchased a XF and just realized it didn't have xenon lights on it and the standard halogen. To my dumb mistake I thought it would because of the projectors on the car.
So now I'm wondering if anyone has done this buy purchased the bi-xenon after and installed it themselves or taken it in to do so? If so how much is this going to cost roughly. Or if anyone can direct to where I can purchase them other than Jaguar.
Looking for OEM not really for aftermarket product.
Old May 8, 2011 | 03:29 AM
Cadillac's Avatar
You can contact our vendors
NALLEY , JPAM
You can also get a discount since you're a forum member
Old May 8, 2011 | 07:37 PM
hawee's Avatar
is it possible? i heard that it isn't. So i'm confused. Doesn't seem difficult to purchase the bi-xenon headlight assembly and replace the current halogen ones.
Old May 9, 2011 | 10:23 AM
CashmereLeaper's Avatar
Thumbs up Bi Xenon HID Conversion
Last year I did a conversion to HID on my Lexus GS300. It was very easy and the results were beyond my expectations. Took under 1 hr to install.
I used the www.hidxenonlights.com and AGT digital HID Kit Slim ballasts for $149.99 and specified the 6000 kelvin bulbs (whitest white).
Unbelievable difference and after 1 year they are working like day one.
They have them for your XF. Also, if you are looking for replacement D1S HID bulbs at a great price go to www.highperformancebulbs.com and order the Philips Ultinon 6000k's for $184.99 a pair.
Old May 9, 2011 | 12:32 PM
xjrguy's Avatar
It is not possible to retro-fit xenon HID lights to a Jaguar after the fact. Entire wiring harness are different. I one case, after a body repair, one headlamp worked and the other didn't. Turned out the body shop installed the wrong front harness and light wiring either wasn't there or went to the wrong terminals in various connectors.
You'll have to try an aftermarket route if you want HID.
Cheers,
Old May 9, 2011 | 01:39 PM
hawee's Avatar
ah man i really hate that
i know for audi you can easily swap out the headlight assembly.
quick question about aftermarket, is it simply plug and play or does it require some modding.
Old May 16, 2011 | 10:04 PM
renealv's Avatar
Same thing happend to me with a Volvo s60 t6 i just sold. You get so excited about the car, and you expect that comes as a standard....
Why don't you take the issue to the dealer, there will always be a change for a good deal before losing a good dissapointed client.....
Old May 20, 2011 | 09:54 PM
ydm2000's Avatar
True hid is 4300k dont buy anything over 5000k or you will look like a teenager with blue lights
Old May 21, 2011 | 09:49 PM
Need4Spd's Avatar
+1 In addition, color temps over 5000k are too blue to enable you to see well at night. They actually provide LESS usable light than 4300k, which are about optimum.
Old Jun 7, 2011 | 02:01 PM
tim05w's Avatar
On BMW you could do a conversion but you needed to purchase the entire headlight assembly plus reflash the ECU. It is a HUGE and costly conversion that I would imagine be the same on a Jaguar.
You could go for the other route which is simply purchasing a HID bulk/harness/balast kit which replaces the type of bulb you currently use. Takes some simple wiring to get the light working. The downside for this route is the projector won't be optimized for the HID bulb which means the light and lines won't be clean.
Your final option is look for a shop to retrofit just the projector and bulb for you, but that would be costly as well.
Old Aug 7, 2011 | 11:22 PM
hawee's Avatar
Need some help.
So i've been looking and asking around and it seems impossible to have any OEM xenon lights installed because of wiring.
So now, i guess i will have to go for aftermarket. I was wondering if any of you have successful accomplished this and if so please let me know where and how you did it.
Jpav27
Jul 31, 2022 06:43 AM
afterburner1
Dec 16, 2015 12:12 AM
redrover41
23
Sep 25, 2015 01:33 PM
avern1
Sep 8, 2015 06:25 PM
XCrossWindsX
Sep 5, 2015 10:58 PM
