Help required
Thank you , I have a 2011 XF 2.2 TD luxury automatic . I got lucky and after watching a utube clip I found that by turning the ignition off , then locking and unlocking the car , the sat nav returned to normal from the dynostic screen when it was restarted.
That said my issue remains , it has a 2011 sat nav program that doesn’t show my street or house, I would like to upgrade to the 2019/20 version. , I checked and there is no cut out in the boot leading to an obvious DVD drive,
Would any owners of a 2011 model know if there is a drive hidden behind the boot lining and is it a DVD or is there a different way to update . I can’t see any DVD or USB port that would seem to solve it.
Many thanks guys , my 2011 software now up and running again and from another source on here I have also gleaned that my 2011 XF is likely to be the 2012 build with the hard drive hopefully fed by the USB
