Help required
Old Nov 6, 2020 | 12:50 PM
Hoffers's Avatar
Default Help required
I have stupidly accessed the diagnostics screen of my sat nav to find out it’s date and am stuck in it , next , back button , any menu doesn’t work , any ideas please
Old Nov 6, 2020 | 01:30 PM
JagV8's Avatar
If you selected the update it's erased the firmware and you'll need an appropriate disc to try to reload it. There's a HUGE thread about it if you look.
Old Nov 6, 2020 | 01:46 PM
It would be good to know what model and year you have.
Old Nov 6, 2020 | 06:58 PM
Hoffers's Avatar
Default Thanks
Thank you , I have a 2011 XF 2.2 TD luxury automatic . I got lucky and after watching a utube clip I found that by turning the ignition off , then locking and unlocking the car , the sat nav returned to normal from the dynostic screen when it was restarted.
That said my issue remains , it has a 2011 sat nav program that doesn’t show my street or house, I would like to upgrade to the 2019/20 version. , I checked and there is no cut out in the boot leading to an obvious DVD drive,
Would any owners of a 2011 model know if there is a drive hidden behind the boot lining and is it a DVD or is there a different way to update . I can’t see any DVD or USB port that would seem to solve it.
Old Nov 8, 2020 | 10:05 AM
Paul_59's Avatar
Banned
If all you were doing is viewing the nav software version I would try switching off ignition and optionally disconnecting the battery then reconnect and power on
Old Nov 9, 2020 | 03:08 AM
John Williams's Avatar
If you have no DVD then you have the built in sat nav drive updated via the usb under the centre armrest!
Old Nov 9, 2020 | 10:48 AM
Hoffers's Avatar
Many thanks guys , my 2011 software now up and running again and from another source on here I have also gleaned that my 2011 XF is likely to be the 2012 build with the hard drive hopefully fed by the USB
rayalbers
Feb 7, 2023 05:11 PM
Yorkyni
May 17, 2017 04:33 PM
Trevoready
Mar 19, 2015 06:45 PM
Dick
Jun 4, 2013 10:41 AM
