Hood Open Warning but hood closed and latched
Old Jun 21, 2023 | 08:04 PM
larryorgnist82's Avatar
Default Hood Open Warning but hood closed and latched
Hello all,
Been quite a while since I posted anything, but this one has me stumped. At first, if I opened the hood and closed it, the warning would go away and everything worked as normal. Now it is on and won’t clear for any reason. I have cleaned every contact that I can find in the latch but no good. Is there a micro switch somewhere that I am missing? Where would it be located? At this point, I am unable to lock the car because of the open hood fault! Thanks for any suggestions.
Oh, 2009 XF SC
Thanks in advance
Larry in Afton, Va
Old Jun 22, 2023 | 02:29 AM
John Williams's Avatar
The microswitch is on the right latch as you look under the bonnet, the swich is part of the latch. You can bridge the 2 wires to bypass the switch, but often the switch can be freed-up with wd40.
Ken D
Jun 15, 2022 07:17 AM
Hockey_Steve
Mar 18, 2022 11:25 AM
yidal8
Aug 16, 2020 06:30 AM
Salu498
Mar 31, 2017 02:15 PM
EZDriver
Oct 28, 2014 04:12 AM
