Horn sounding twice when unlocking doors
Old Apr 23, 2015 | 04:50 AM
blyth63's Avatar
Default Horn sounding twice when unlocking doors
HI Guys,
I wonder if you can help me.
As of yesterday my 2012 XF has started to sound the horn twice when using the fob to unlock or the door handle. This happens both on single and dual entry.
Can this be set up so as not to sound the horn on the control screen?
Thanking you in advance
Steve
Old Apr 23, 2015 | 04:55 AM
Welcome to the forum Steve,
I've moved your question from General Tech Help to X250 forum. Members here with the same model will be able to help.
Old Apr 23, 2015 | 06:25 AM
OzXFR's Avatar
This issue was discussed recently on another forum, see here:
Double beep on entering?
Old Apr 23, 2015 | 07:57 AM
blyth63's Avatar
Thanks for that.
Sadly no solution was posted.
At least I now know i'm not going mad!
Old Apr 23, 2015 | 01:27 PM
acxzxca's Avatar
Default I had the same problem
Ill just tell you what I experienced even though its on the other page. So I couldn't lock my door and it would beep everytime I tried. The only way was through the actual key insert. Car starts and everything was good but the dashboard indicated my trunk was open. I checked it out but apparently something on the inside broke and my car thought the trunk was open. So if there is a door open or not closed all the way, it will beep and it will not lock... hope that helps. And yeah look for others posts first! It Def helps get answers faster
Old Apr 27, 2015 | 11:41 AM
jimforrest (uk)'s Avatar
Mine did that all the time - very annoying late at night. I mentioned it to the Technician while it was in having the tensioners done so he stooped down, reached into the R/H wheelarch, and pulled the cable off the sounder, Pure bliss!
Old Apr 27, 2015 | 02:55 PM
2010 Kyanite XFR's Avatar
It's definitely something to do with a door or trunk being open. Had it happen to me this weekend.
Old Apr 28, 2015 | 05:27 AM
jaguny's Avatar
Also happens if you leave a fob in the car.
GordoCatCar
Jan 2, 2017 01:10 PM
Chuck Schexnayder
Sep 18, 2015 03:10 PM
kabs3012
Sep 12, 2015 10:40 AM
kabs3012
US Midwest
Sep 10, 2015 01:17 PM
Jay48
Sep 7, 2015 09:30 PM
