How do I replace the accessory belt?
Old Mar 25, 2021 | 03:44 PM
Oxidizer2k's Avatar
Default How do I replace the accessory belt?
Doing my water pump and I have both supercharger and accessory belt off the pulleys but I’m struggling to figure out how to get the accessory belt off. Is there anything else I need to remove? Seems to be stuck in one place.
can’t get it off of the pulley back there.
Old Mar 25, 2021 | 05:31 PM
JBzXJ40's Avatar
You can try to sneak it past the bracket that's there on the left of your picture - otherwise you'll need to remove that pulley to the left of your arrow, and the bracket its bolted to
  1. Torque: 55Nm
  2. Torque: 25Nm
Old Mar 25, 2021 | 06:09 PM
Oxidizer2k's Avatar
Ok thanks. I tried to get it out of there with the bracket still there but it looks like I may have to remove it after all.
Old Apr 1, 2021 | 08:13 AM
kansanbrit's Avatar
No, you don't have to to remove it, you twist the belt and slide behind.
Old Apr 1, 2021 | 12:21 PM
Oxidizer2k's Avatar
Awesome! But I tried it and failed. Probably didn’t try hard enough. I haven’t replaced the belt so I’ll give it another go.
Old Jun 19, 2024 | 07:24 AM
SC Gary's Avatar
Default Bracket does not have to come off
Correct!, start there, flip and feed behind bracket, takes a couple tries, but does work.
Jeroen
Aug 22, 2023 07:11 PM
User 070620
General Tech Help
Dec 3, 2018 08:51 AM
RaceDiagnostics
Sep 12, 2016 04:39 PM
QuikCat
Nov 7, 2013 05:17 PM
spuddyo
Jul 29, 2013 09:20 AM
