how many pistons on 2010 xfr brakes?
Old May 6, 2020 | 07:14 AM
Enzo Valetti's Avatar
Default how many pistons on 2010 xfr brakes?
Hello everyone I can't seem to find out if I have 4 or 6 piston brakes on my xfr 2010 I'm searching the internet and I can't find any answers it's really annoying so if anyone knows please let me know that little piece of information thank you
Old May 6, 2020 | 12:02 PM
TXFireblade's Avatar
They have a 2 piston sliding caliper I believe.
Old May 6, 2020 | 12:46 PM
Adam J's Avatar
i believe 2 piston front and single piston rear. they are huge calipers and rotors, but fairly conventional piston design. remember the rear pistons need to be turned in.
Old May 7, 2020 | 05:12 PM
OzXFR's Avatar
Yes, definitely 2 piston front and single piston rear, both sliding caliper design.
Old Jul 7, 2020 | 02:45 PM
Kaeghl's Avatar
You have to remember that more pistons does not mean a better brake, you want to look at the total surface area being applied, and our two pot fronts and one pots rears are well designed and do a very good job.
Old Jul 7, 2020 | 04:52 PM
H.Jones's Avatar
I will politely agree on the fronts, and disagree on the rears. The rear XFR and XFR-S caliper design and pad design are not adequate for a car of this size.
If the rear pads were bigger they wouldn't need to be changed twice as often as the front brakes.
Old Jul 8, 2020 | 06:29 AM
JagV8's Avatar
Who has reported that? I don't see it as a common issue so may be dragging brake(s) on your car.
Old Jul 8, 2020 | 06:43 AM
OzXFR's Avatar
Pretty much every XF owner has reported this.
Multiple reasons why the rear brake pads need replacing twice as often as the fronts:
1. The anti-dive system which applies the rear brakes earlier and harder than the front brakes.
2. The EPB on the rear brakes and the way it operates.
3. The rear brake pads are a lot thinner than the front brake pads.
Being "bigger" would not help with 1. or 2. but being thicker would help a lot with 3.
newfire
Sep 27, 2022 07:12 AM
Ellentoft
Other Areas
Sep 19, 2017 02:08 AM
Escolar
Aug 11, 2012 08:17 PM
2010XFR
Dec 22, 2011 10:44 AM
jaguarevan
Aug 7, 2009 09:00 AM
